How Many Small Cars ... |
euro911 |
Jul 11 2015, 12:46 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
can one fit into these garages?
Without the 4-post lift, I count 4 in the RV garage, and 3 in the other garage (IMG:style_emoticons/default/smile.gif) |
rhodyguy |
Jul 11 2015, 12:51 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,092 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
What is on the outside of the 35' wall? I see 4 cars and no lift or 3 cars on the floor with any car living on the lift stationed in the rear with plenty of room to get around, cabinets, what ever. How tall is the ceiling?
Tom_T |
Jul 11 2015, 02:24 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
can one fit into these garages? Without the 4-post lift, I count 4 in the RV garage, and 3 in the other garage (IMG:style_emoticons/default/smile.gif) Probably so, but it will be tight + not all your rides are 914. Agree that you should check clear ht. in the RV Garage for the lift, since I'd assume that the other garage under the 2nd floor bedrooms would probably only be 9-10' & not high enough. If enough sideyard space, then it's also possible to tack on a shed roofed garage/shop to the right of the RV Garage, as what I think Rhody is getting at! 4-post lift is usually one over & one under, or a custom built double-wide is 2-up/2-down. I have a non-standard 17'-6" outside width 2-car garage too, so I'd have to use one that's 16'-6" w. + raise the roof (1921 detached garage) - so I know some lift makers can do them 16' for your RV garage. Otherwise the posts will cut down the 16' width & you may not fir one beside a std. 8' w. 1 car lift. Is that 27.7' section of side wall an actual wall - or open - or a common wall with the unit next door to the left? I ask cuz that's usually a property line type designation used there. Assuming new AZ digs?? (IMG:style_emoticons/default/confused24.gif) Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Andyrew |
Jul 11 2015, 03:02 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Looks like a killer pad!
2 regular cars in the main pad plus a little storage for "normal" life, RV should be enough for 3, One sideways on rollers, or in a dedicated work bay with work area around it and two behind it with probably a pull down ladder access storage above. |
euro911 |
Jul 11 2015, 04:32 PM
This is a single family residence on a tad less than 1/4AC. East property line is approx 10~15' from the RV garage. Only plan to fence off the side and back yard areas (no shed(s) envisioned (yet).
A lot survey is part of the permit process to erect a fence. The existing property markers show the property line is very close to the east neighbor's west walkway. They might not be too happy about that, but that's why we'll be pulling the permit. We need to enclose the yard for our doggies (IMG:style_emoticons/default/dog.gif) The Danmar D7 lift is 8.75' wide (at the bottom post flanges), so it should only take up 1/2 of the width in the RV garage. It has dollies, so it can be move to the ideal location as needed. I haven't had a chance to measure the height, but it appears to be more than adequate. The main garage is below the kitchen/dining area. There's propane gas existing at the water heater in the garage, so I can plumb gas to the kitchen range and oven if my wife decides she doesn't like the electric ones (IMG:style_emoticons/default/confused24.gif) If I had to, I think I can squeeze two small cars tandem in the west side of the main garage, plus one more (and some motorcycles) in the remaining space. I'd like to get some of that nice epoxy floor finish done in there (IMG:style_emoticons/default/idea.gif) Still haven't decided on which vehicles will reside in AZ and which ones will stay in CA just yet. Escrow is supposed to close on the 24th of July ... (IMG:style_emoticons/default/mueba.gif) There's a lot of stuff to deal with when moving to another state (IMG:style_emoticons/default/wacko.gif) |
EdwardBlume |
Jul 11 2015, 05:03 PM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
EdwardBlume |
Jul 11 2015, 05:08 PM
You could fit my rig in there....
Attached thumbnail(s) |
Sedonut |
Jul 11 2015, 05:58 PM
Member Group: Members Posts: 67 Joined: 18-May 14 From: Sedona, AZ Member No.: 17,367 Region Association: Southwest Region |
I don't recommend a Danmar in a two car garage. It's just a matter of time with the spyder replica gone until I hit or scratch something.
On the plus side, I have 3 cars, 3 motorcycles in a standard two car garage. Just because you can do it, does not mean you should. |
euro911 |
Jul 11 2015, 07:07 PM
Yeah, the lift is going in the RV garage, Tony ... no second thoughts about that.
We may only need room for 2 cars and a couple of bikes in the main garage ... the Tacoma and some project cars in the RV garage for now. Here's the preliminary plan (subject to change at any time) Ghia , 1 914 and some bikes will stay in CA + whatever vehicle we drive back & forth. 1 914, 1 912, 1 911, Tacoma and some bikes will reside in AZ 1 911 to the metal restoration shop in CA (long term project) Sell Vanagon, '99 Beetle and a couple bikes ... Looks like I may have more room than I need ... ... ... naw (IMG:style_emoticons/default/laugh.gif) |
cpavlenko |
Jul 11 2015, 09:58 PM
Member Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
Where in AZ, I'm in Chino Valley. Been here 10 yrs now. Maybe we can hook up someday. My view from the front of house is the San Francisco peaks at Flagstaff.
euro911 |
Jul 11 2015, 10:11 PM
Payson (IMG:style_emoticons/default/smile.gif)
Sedonut |
Jul 12 2015, 12:05 AM
Mark,
You can never have too many garages. I don't think you can have too many cars either. I like fixing them up, and it is a savings account. The way 911's and 912's have been going up, they are a great investment too. I hope 914's follow. Tony |
KELTY360 |
Jul 12 2015, 07:44 AM
914 Neferati Group: Members Posts: 5,036 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
As satisfying as it is to fill a garage with cars, the ultimate luxury is to have an open bay. However the discipline and self control required to maintain an open bay is generally beyond most car guys.
Nature abhors a vacuum. |
euro911 |
Jul 12 2015, 06:06 PM
I'm definitely thinning the herd, Marc, and will have two different locations to divide up the remaining vehicles. I think this is going to afford a lot more elbow room - at both locations (IMG:style_emoticons/default/smile.gif)
euro911 |
Jul 24 2015, 09:28 PM
We signed the final documents this morning (IMG:style_emoticons/default/smile.gif)
I have a little cleaning-up to do in the RV garage. Would like to apply an epoxy floor coating or maybe some B&W checkerboard vinyl tile? (IMG:style_emoticons/default/confused24.gif) . I plan to install an additional pedestrian door in the back wall. Might put some thought into building a loft in there too (IMG:style_emoticons/default/idea.gif) |
euro911 |
Aug 10 2015, 06:12 PM
Escrow closed on 7/28 and the seller's agent sent a clean-up crew to clear out the garage.
Dianne is packing boxes of domestic items and I've been s l o w l y staging boxes and crates of parts at the shop. We'll be making the first run when I get a full trailer-load ready to go, probably sometime in September. Probably won't be transporting any vehicles on the first couple of runs. Maybe in October, I'll host a lift-disassembly party/BBQ and get all the heavy tools loaded up for a second run (IMG:style_emoticons/default/idea.gif) Sure hope we don't get the 'Storm of the Centruy/El NiƱo' weather conditions this coming winter (IMG:style_emoticons/default/pat.gif) |
KELTY360 |
Aug 10 2015, 06:25 PM
We signed the final documents this morning (IMG:style_emoticons/default/smile.gif) I have a little cleaning-up to do in the RV garage. Would like to apply an epoxy floor coating or maybe some B&W checkerboard vinyl tile? (IMG:style_emoticons/default/confused24.gif) . I plan to install an additional pedestrian door in the back wall. Might put some thought into building a loft in there too (IMG:style_emoticons/default/idea.gif) Houndstooth. Is that where the lift goes? How cool would it be to build a wrap around loft that would gave you access to the car from above? |
JmuRiz |
Aug 10 2015, 06:57 PM
914 Guru Group: Members Posts: 5,434 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
2 in the regular garage (with bikes and motos in there too). 3 in the RV garage (tandem with one on and one under a lift with another near the door)
That'd give tons of space around them. Having space to fully open doors is VERY nice when working on, restoring, or cleaning a car. BTW your parts loft is a great idea, with 16' wide you can have stair access along one of the walls. I have one above the door in my 22x24 space (ladder access) and it's a great addition. |
r_towle |
Aug 10 2015, 07:26 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
You could fit 7 914 s in that rev garage with wheel dollies
euro911 |
Aug 10 2015, 07:32 PM
Very good ideas (IMG:style_emoticons/default/smile.gif)
I thought about a loft for storing parts, just not sure exactly where or how large. I'll have to give it some more thought when we get settled in. |
Lo-Fi Version | Time is now: 8th June 2024 - 08:03 PM |
