Clutch cable sound in tube, Just started after I replaced the pedal cluster ? |
jim_hoyland |
Jul 11 2015, 03:01 PM
Get that VIN ? Group: Members Posts: 9,314 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I removed the shifter and pedal cluster. After reconnecting the clutch cable to thr pedal cluster and tranny, I hear the cable rubbing against the clutch cable tube. When I reach into the tunnel behind the shifter and hold the tube while depressing the clutch I can feel the tube making friction with the cable ?
Any thoughts on this ? |
76-914 |
Jul 11 2015, 03:43 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Is there an old piece of sheathing still in the tube? Can you use a mirror to verify you haven't crossed cables? (IMG:style_emoticons/default/beerchug.gif)
Dave_Darling |
Jul 11 2015, 04:59 PM
Double-check the clutch and throttle cables at the front of the center tunnel. They can get wrapped around each other, and that might make noise or move one or the other so that it rubs a bit.
Look carefully at the clutch tube while you push the pedal. If it moves, it has broken loose and needs to be re-welded. --DD |
McMark |
Jul 11 2015, 10:39 PM
Yup. Dave's got it.
rhodyguy |
Jul 12 2015, 07:01 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,085 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
edit. Wrong thread.
Lo-Fi Version | Time is now: 3rd June 2024 - 07:37 AM |
