Brake problem, No fluid getting to pass rear |
Rhodes71/914 |
Feb 26 2005, 05:42 PM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
Have driven my car just a few miles since I got the 2L in and on my longest and last drive the brakes seemed pretty spongey.
I knew I had some more bleeding to do after installing the rebuilt ones I got from Eric Shea. It was also pulling to the drivers side a bit. When I tried to bleed the rear passenger caliper I got nothing. Pulled the line out and nothing out of there either. There is fluid in the caliper that I can see when I removed the fitting. Loosened the fitting at the Porportioning Valve that goes to that caliper and got plenty of fluid coming out there. Could it be possible that something is clogging the line? What else to check. Rear drivers side bleeds fine. |
Type 4 |
Feb 26 2005, 05:51 PM
Member Group: Members Posts: 412 Joined: 30-September 04 From: Costa Mesa Calif. Member No.: 2,866 |
Did you remove the rubber line? They can swell shut.
Cap'n Krusty |
Feb 26 2005, 06:01 PM
Agreed. I see it often on older cars. Might as well change all those original hoses. Plan on an adventure, and soak all the fittings with your favorite REAL penetrating oil for a few days before attempting the repair. OE style hoses aren't too expensive and will last for 10-20 years. Replacing the rear ones is usually a PITA. Good luck! The Cap'n |
jwalters |
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
(IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) The inside of the rubber lines, new or old, can come apart from the inside and actually completely block fuid passage. I say this because I have seen this happen new and old alike.
Rhodes71/914 |
Feb 26 2005, 06:30 PM
Lovely, isn't that just typical, fix one thing and something else breaks.
Supposed to snow on Monday anyway. I'll check it out tonight and let you know what I find out. |
Lo-Fi Version | Time is now: 7th June 2024 - 03:41 PM |
