| Engman |
Feb 26 2005, 09:43 PM
Zoisite ![]() ![]() ![]() Group: Benefactors Posts: 1,349 Joined: 25-March 03 From: New Albany, IN Member No.: 475 |
Please see http://engmanparts.com for details. Set of 2 - will work with up to a 31mm sway bar.
PM or email me..... M Attached thumbnail(s)
| Jeroen |
Feb 27 2005, 07:22 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Can you explain a little?
I can see there's more meat to the plate it self, but what about the extra holes? |
| Engman |
Feb 27 2005, 01:58 PM
The 3 holes are to be puddle welded to the car, then weld the edges all around. This plate is almost 50 percent larger than the old ones - you will have to notch out more area to fit it in.
M |
| Andyrew |
Jan 30 2006, 05:24 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
Whats the ID of the hole?
| Engman |
Jan 30 2006, 06:42 PM
You can go up to a 31mm sway bar - largest I know of.
M |
| Andyrew |
Jan 31 2006, 03:11 AM
Whats the ID in inches?
I have a 1 1/4in sway bar.. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
| Engman |
Jan 31 2006, 12:26 PM
These are sized at 1.24" currently - I *can* open up a set to 1.31" if you are interested.
On a side note - what bar are you planning on running? M |
| Andyrew |
Jan 31 2006, 02:47 PM
Nascar bar, 1 1/4 in 49 spline turned down to 3/4 inch. should provide between 70-200lbs of stiffness (or more) and i'll make the arms adjustable.
Bar I got from Brett (thanks!!) Bushing or bearing is my only problem. but I have a couple ideas on that. Andrew |
Lo-Fi Version | Time is now: 13th March 2026 - 12:34 AM |
