Ignition setup for Mallory Unilite Distributor for 2258cc, Add Hyfire 6AL and Mallory Coil? |
lonewolfe |
Jul 18 2015, 02:36 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
I need your feedback on completing my ignition setup for a 2258cc motor. I've already purchased a Mallory Unilite Distributor, Mallory Active Power Filter and have ordered the custom MSD spark plug wires for Mallory Unilite from Tangerine Racing. I'm thinking of getting the Mallory Hifire 6AL 8353 CD Box and perhaps a Mallory Coil as well. What have you guys had success using and what do you suggest?
lonewolfe |
Jul 18 2015, 02:42 PM
Interestingly enough, when I went to the Mallory website I see that Mallory has been purchased by MSD. Where does that leave us?
Mark Henry |
Jul 18 2015, 02:51 PM
MSD or mallory they both work, it depends on your state of tune often a blue coil is all you need.
Interestingly enough, when I went to the Mallory website I see that Mallory has been purchased by MSD. Where does that leave us? Short term likely not much will change. |
lonewolfe |
Jul 18 2015, 02:55 PM
MSD or mallory they both work, it depends on your state of tune often a blue coil is all you need. Interestingly enough, when I went to the Mallory website I see that Mallory has been purchased by MSD. Where does that leave us? Short term likely not much will change. Thanks for the reply Mark. Hey, I've got a question for you and am sending you a PM. |
screenguy914 |
Jul 18 2015, 03:39 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
Since you already purchased many Mallory components, I'd suggest ... Mallory or compatible MSD which now markets the Mallory name/line of products.
My internet search doesn't show a Mallory 6AL 8353 CD Box. It could be a very recent relabeled MSD 6AL CD box (compare images and features to confirm if you can find them). There's a Mallory HyFire 6AL2 box (6861M) that looks similar to a MSD 6AL or Crane "Hi-6" ign. box, but that's a WAG. In addition to having a better build quality distributor, the system could also benefit from their breakerless module which eliminates the contact points. The ignition coil specs should also be compatible with the ignition box you choose to install. I think you'll find similar features among most manufacturers, the difference would be in their individual quirks, QC and customer service responses. Not sure whether your tach will need an adapter to work with the new components. Mallory/MSD can provide you that information as well as the tach adapter. MHO, Sherwood |
lonewolfe |
Jul 18 2015, 03:45 PM
The Unilite has an optical system so no mechanical points. I got the numbers wrong for the Hyfire VI AL though. It is a 6853M model with built in rev limiter.
stugray |
Jul 18 2015, 04:54 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I have exactly this system.
Mallory Unilite with optical pickup (fromTangerine racing). A MSD 6AL (digital) and a Bosch Blue coil. I run the 8.5 mm MSD wires with LS1 90-degree boots at the plug end. It hooked right up and ran the very first time. The output of the MSD will not work with the stock Tach so you will need the Tach-Adapt product. You will also need to reset your timing after installation. If you have any specific question i can help out, but it was pretty straight forward. |
lonewolfe |
Jul 18 2015, 06:59 PM
I have exactly this system. Mallory Unilite with optical pickup (fromTangerine racing). A MSD 6AL (digital) and a Bosch Blue coil. I run the 8.5 mm MSD wires with LS1 90-degree boots at the plug end. It hooked right up and ran the very first time. The output of the MSD will not work with the stock Tach so you will need the Tach-Adapt product. You will also need to reset your timing after installation. If you have any specific question i can help out, but it was pretty straight forward. Why did you choose a MSD 6AL over a Mallory Hyfire 6AL for your setup? I guess that's what's puzzling to me. It seems one would be better to use components that were made to go together instead of mixing components from different brands. It seems the Mallory unit would be better because it has a built in rev limiter and also will work the tach without an adaptor. It seems a lot of people mix the Mallory distributor with a MSD CD BOX and I want to know why one is preferred over the other. |
FlatIV |
Jul 18 2015, 08:46 PM
AP Group: Members Posts: 55 Joined: 4-May 06 From: Circleville, Ohio Member No.: 5,978 Region Association: None |
Disreguard
Andrew |
stugray |
Jul 18 2015, 09:47 PM
Mueller |
Jul 19 2015, 10:04 AM
For my old setup, (and Randal) we both had a LINK EFI, Mallory Unilite and MSD box.
LINK spec'd out the MSD box since it was easier to hack and modify to be driven by the LINK. I think we had to remove a resistor and replace with different value, been way too long. It seems like MSD just had the market cornered for that particular unit so it was more popular. |
Mueller |
Jul 20 2015, 12:41 PM
Found this while looking for a cheap used MSD or Mallory distributor.....which don't exist for the nice billet distributors (IMG:style_emoticons/default/sad.gif)
Package deal Slight highjack...the Type IV can use a standard Type I distributor correct? |
Mark Henry |
Jul 20 2015, 12:52 PM
Found this while looking for a cheap used MSD or Mallory distributor.....which don't exist for the nice billet distributors (IMG:style_emoticons/default/sad.gif) Package deal Slight highjack...the Type IV can use a standard Type I distributor correct? Yes the T1 and T4 dizzy fitment are the same, main issues are physical size IIRC the MSD body is too big for a T4 tinwork. My cheap out on a Mallory is to find a good used redcap dual point Mallory, and use one set of points to fire the MSD. You can also retrofit a set of pertronix in the old Mallory. These are 100% exactly the same as a Unilite, except it doesn't have the optical P/U I've done this many times, MrHyde (Mike Hyde) is running one of the moded old red cap Mallory's with pertronix, per my recommendation, on his 2300cc. BTW points firing a MSD-AL6 will likely go 50K before they need adjusting and may never wear out. This is because firing the MSD puts very little voltage thru the points. |
lonewolfe |
Jul 20 2015, 01:07 PM
Thank you all for your replies. I ended up ordering everything from Mallory. If the Mallory CD box fails them I'd give a MSD unit a try!
Lo-Fi Version | Time is now: 11th June 2024 - 05:11 PM |
