How big is a 20 over 73' 2.0L |
shelby/914 |
Jul 20 2015, 03:22 PM
Senior Member Group: Members Posts: 804 Joined: 24-August 05 From: Foxfield, Co Member No.: 4,655 Region Association: Rocky Mountains |
Four or five years I had the chance to buy a spare 2.0L for a reasonable amount. It came out of a running car which had just been driven by someone I'd trust. We recently got it out to install in a friends tub for a test run and so he could have a running car while he builds an engine. While cleaning it up we noticed that the case was stamped 20/20 indicating it had been bored out. Was able to email the former owner who confirmed that it had been bored and as he remembered has a non stock cam. So how big would it be if 20 over is correct?
Dan |
914Sixer |
Jul 20 2015, 03:38 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
20/20 is probably referring to the crankshaft and bearings. Has noting to do with bore size of the pistons and cylinders. They would be stated in mm.
colingreene |
Jul 21 2015, 05:26 AM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
agree
Dave_Darling |
Jul 21 2015, 08:54 AM
20 over would be 0.020", which is 0.5mm. The dimensions of a stock 2.0 are 94mm x 71mm, for 1971cc. 94.5mm x 71mm would be 1992cc.
But the stamping is far from a guarantee of the size of the cylinders... --DD |
Mark Henry |
Jul 21 2015, 10:13 AM
Although .5mm over on piston & cylinders is something I've seen in the manual I've never seen it done. And I've tore apart lots of VW of Canada rebuilds.
The VW Canada headquarters in Toronto used to rebuild all the VW engines in North America until the early 90's. All as in all the official VW dealer engines, they had a whole engine production line, I toured it in high school. My guess it would be case and crank as well. |
sean_v8_914 |
Jul 21 2015, 10:15 AM
my guess is that the crank main journals have been machined to 0.5mm under size and the rod journals are also machined to 0.5mm under size. like dave said
914runnow |
Jul 21 2015, 12:57 PM
Member Group: Members Posts: 340 Joined: 19-April 04 From: Modesto California Member No.: 1,948 Region Association: None |
case is stamped on the top and in the middle
020 020... it is a Ga motor 6529... |
Heeltoe914 |
Jul 21 2015, 01:49 PM
Senior Member Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
Crank and bearing... No problem for a street motor I try to avoid for a race motor. But thats just me.
Happy motoring |
Lo-Fi Version | Time is now: 11th June 2024 - 08:34 PM |
