Please Help Electrical Issue |
rdgabert |
Jul 24 2015, 10:28 AM
Newbie Group: Members Posts: 14 Joined: 22-October 14 From: SD Member No.: 18,050 Region Association: Upper MidWest |
Hello,
I have a 1974 1.8 that the ignition switch failed on. I have replaced the switch but now the horn, windshield wipers, cigar lighter, and headlights do not work. I pulled the new switch and that tests fine. I have no power going to the 16 amp wiper fuse and am unable to figure where this is suppose to get it's power. Any ideas? Does the seat belt relay have anything to do with this? TIA Robert |
JeffBowlsby |
Jul 24 2015, 01:29 PM
914 Wiring Harnesses Group: Members Posts: 8,527 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Check the fuses and that all connectors are connected. Sounds like the steering column switch connectors may be loose or disconnected.
914Sixer |
Jul 24 2015, 02:37 PM
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
As Jeff said check the connections. Make sure you are not ONE PIN OFF, on the plug
rdgabert |
Jul 24 2015, 02:44 PM
Thanks guys, I found the spade connector that goes on the X circuit on the switch had pushed it's way out. Just spread open the little tab and pushed it back in the connector and all is well. Duh!
Robert |
Lo-Fi Version | Time is now: 3rd June 2024 - 02:42 AM |
