How do you remove the back pad, Pad behind the seats |
clark2 |
Feb 27 2005, 03:30 PM
Newbie Group: Members Posts: 21 Joined: 2-February 05 From: Dallas, TX Member No.: 3,553 |
I took out the seats and removed the 4 screws at the bottom of the pad and the hood knob, but it seems to be held by something on the top. Does it lift up and out or are there screws I am missing?
Aaron Cox |
Feb 27 2005, 03:36 PM
it has tabs holding it in.
pull the bottom of the backpad forward 8 inches and the tabs will diengage..... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
scotty914 |
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
pull the bottom down and out, or is it up, or it might be to the side, dont rmember which side but if you go the wrong way the car blows up
down and out |
clark2 |
Feb 27 2005, 03:37 PM
Thanks, I will try it right now - I love this sight.
r_towle |
Feb 27 2005, 04:42 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Back pad needs to go up or the car will catch on fire and the ensuing flames will create a large vacuum that sucks you into the passenger side longitudinal....once inside though you will see Miles.
Rich |
Rand |
Feb 27 2005, 05:25 PM
UP.... lift up. The tabs at the top hold it in place. The fiber board material that holds the tabs that fit into the slots will rip loose on old material, so be careful. If all the screws and clips are off, it should lift up then away from the firewall.
Garland |
Feb 27 2005, 06:51 PM
Restoration Fanatic Group: Members Posts: 1,329 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
I Need to end this link with correct information.
You must lower the pad to slide the clips that are mounted to the backpad down, and out from the firewall. Aaron Cox post is correct: "it has tabs holding it in. pull the bottom of the backpad forward 8 inches and the tabs will diengage....". |
Lo-Fi Version | Time is now: 9th June 2024 - 05:51 PM |
