Ignition wiring to butt connectors question, Steering column wires to butt connectors 1970-71 914-4 |
pgollender |
Jul 28 2015, 01:56 PM
Member Group: Members Posts: 193 Joined: 5-July 11 From: Sacramento Member No.: 13,281 Region Association: Northern California |
I need help in connecting my new ignition wires to an old 1970-71 wiring harness.
I built an engine test stand and connected an old harness but I wanted to simply use a new ignition switch to turn it on, but I dont know which of the 12 butt connectors to connect to the 4 ignition wires. Haynes electrical section of the manual is too hard to understand and read and trace with any degree of confidence: This what I have: New switch from AA: 4 wires: red black black with red grey Old harness (12 butt connectors) Big RED Big YELLOW Big BLACK Black with white Black with Green Black with green and white 2-browns Grey with red Grey with black Brown with white Yellow with red. Also I have a partial cluster that I want to keep powered: Tachometer and Multi-meter, NO speedo cluster. Any insight would help: |
JeffBowlsby |
Jul 28 2015, 04:59 PM
914 Wiring Harnesses Group: Members Posts: 8,527 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I did this study awhile ago, consider it a draft and use at your own risk. From studying the 12 and 14 pin connectors on the 12-pin 1970 (through early 1971) and 14-pin late 1971 connectors and chassis harnesses. There may be inaccuracies and the 1970 schematic does not indicate wire colors.
Red is usually the main power Yellow is probably the starter With 12 female connectors you have the 1970 chassis harness. Not sure about the ignition switch you have. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 3rd June 2024 - 08:35 AM |
