Intake Studs, Help How to remove and install longer ones? |
dcecc1968 |
Aug 1 2015, 12:59 PM
Member Group: Members Posts: 252 Joined: 31-December 12 From: Concord, NC Member No.: 15,313 Region Association: South East States |
I'm converting from single carb to dual carbs and since I'm using an acrylic spacer, and my current intake studs (@1.25-inch long) are now too short and I need to get longer studs ~1.5-inch.
Can I get these at the LAPS or is there something special about them? One of the studs came out easy, any tips on getting the other studs out? Thanks for your help. -Don |
zambezi |
Aug 1 2015, 01:45 PM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
use the double nut method to remove screw in studs. Works most of the time with no damage.
SirAndy |
Aug 1 2015, 01:48 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
use the double nut method to remove screw in studs. Works most of the time with no damage. (IMG:style_emoticons/default/agree.gif) |
dcecc1968 |
Aug 1 2015, 05:02 PM
Thanks for the tip
Do you think I can get the longer studs at local auto parts store or should I go to a Porsche dealer? |
Mueller |
Aug 1 2015, 05:19 PM
Thanks for the tip Do you think I can get the longer studs at local auto parts store or should I go to a Porsche dealer? NAPA has a good selection. .... we don't know what autoparts stores you have access to (IMG:style_emoticons/default/smile.gif) The dealer might have longer ones, but unless you have a part number good luck since they will just give you a blank stare if you ask for longer intake studs for a 914. I'd also use millimeters when asking for the longer studs since the parts are metric. |
Amphicar770 |
Senior Member Group: Members Posts: 1,195 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
If studs are broken (or break), mig weld a hex nut to whatever remains even if you are just filling in the hex nut hole to the flush end of the stud. Usually the heat from this process is enough to easily remove the stud (sometimes even just with your fingers).
dcecc1968 |
Aug 2 2015, 06:05 AM
Mueller, Thanks for the help. We do have NAPA here in NC.
Amphicar770 - crossing my fingers that won't be necessary, since I don't weld, but thanks for the tip. |
Spoke |
Aug 2 2015, 08:45 AM
Jerry Group: Members Posts: 6,989 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I put studs in the case for the taco plate and used regular metric bolts from my local ACE hardware store. I bottomed the bolts in the threads and marked where I wanted to cut them.
Removed the bolts and cut them and reinstalled. The same could be done for the intake studs. Plus ACE is open on Sat & Sun. YMMV (IMG:style_emoticons/default/smile.gif) To remove the studs you could do the double bolt method or (assuming you won't use them again) use a really strong pair of vice grips. |
Lo-Fi Version | Time is now: 3rd June 2024 - 03:57 AM |
