Wheel spacer |
Wheel spacer |
StratPlayer |
Aug 3 2015, 10:19 AM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Will a wheel spacer prevent a tire from rubbing on the fender well?
TheCabinetmaker |
Aug 3 2015, 10:53 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
The tire is rubbing on the inside?
Elliot Cannon |
Aug 3 2015, 10:59 AM
JRust |
Aug 3 2015, 11:40 AM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Will a wheel spacer prevent a tire from rubbing on the fender well? Adding a wheel spacer will help if the tire is rubbing on the inside of the fender. If the tire is rubbing on the outside of the fender, you need a wider fender or a narrower tire. (IMG:style_emoticons/default/agree.gif) Elliot is right for once (IMG:style_emoticons/default/poke.gif) |
shoguneagle |
Aug 3 2015, 12:02 PM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
Glad to see Elliot right for once; that means - - - - JRust is definitely wrong on this one. Fact: JRust is always wrong which means Elliot is always right!!
Love to "pick on Mr. Rust". Don't you??? LOL |
Larmo63 |
Aug 3 2015, 12:27 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
Just be sure your lugs or lug nuts are long enough and safe to run spacers
johnhora |
Aug 3 2015, 02:35 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Just be sure your lugs or lug nuts are long enough and safe to run spacers (IMG:style_emoticons/default/agree.gif) Absolute Must! |
porschetub |
Aug 3 2015, 06:50 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Example : studs are 14mm thread you must have 14mm of thread protruding to hold the nut,however.....for alloy nuts a like a little more.
You would most likely get away with a shim spacer (6-8mm) unless you have really fat tyres,from memory anything up to 10mm will be ok without the need for longer studs,cheers. |
jcd914 |
Aug 3 2015, 08:03 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
The rule of thumb I was taught:
For steel nuts & studs you want a nut to stud engagement equal to the diameter of the stud. So for a 14mm diameter stud you want a nut the threads on 14mm or almost 10 turns of the nut (1.5mm thread pitch). For Aluminum nuts on steel studs you want a nut to stud engagement equal to 1.5 times the diameter of the stud. So for a 14mm diameter stud you want a nut the threads on 21mm or 14 full turns of the nut. Jim |
Lo-Fi Version | Time is now: 3rd June 2024 - 08:43 AM |
