off topic once again , aftermarket bucket seat for. 2001 ranger regular cab, whats the best and cheapest way to get this done |
thelogo |
Aug 9 2015, 07:02 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
So my ranger bench 60-40 seat is torn to s#it on the drivers side I tried going the stock replacement route but could only find Extended cab seats on Craig's list And from what I understand regularly cab seats and bracket s Are different from extended cab seats and bracket s Can anyone with ranger experience confirm this ???? So I think I'm just gonna go with a procar seat aka scat for about 200$ and use their Ford ranger bracket which is supposed to Bolt right in and seat right in to bracket I'm 6-2 so seat will always be in the all the way back position And something that sits lower then stock would be good I m assumeing seat belts will be retained and not sure about Airbag or seatbelt wire that plugs into bottom of stock seat . Am I going the right direction here or is there a better way . I thought about the whole 're upholstered route but not sure what that cost . Advice please. ! (IMG:style_emoticons/default/pray.gif) |
thelogo |
Aug 9 2015, 07:03 PM
thelogo |
Aug 9 2015, 09:48 PM
And what is everyone s experience with the so called
Universal Seat bracket s Vs application specific to year make an model ? (IMG:style_emoticons/default/beer3.gif) |
thelogo |
Aug 9 2015, 09:53 PM
Bonnet porn
Anybody ? Hello Attached thumbnail(s) |
Chris914n6 |
Aug 9 2015, 10:02 PM
Jackstands are my life. Group: Members Posts: 3,336 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
If the Ranger is like any other truck, the floor mounts are the same, so the buckets n brackets from the same era should bolt in. A Ranger forum would tell you for sure.
$200 should get you most of the bench recovered. Shop around a little. |
thelogo |
Aug 9 2015, 10:29 PM
If the Ranger is like any other truck, the floor mounts are the same, so the buckets n brackets from the same era should bolt in. A Ranger forum would tell you for sure. $200 should get you most of the bench recovered. Shop around a little. Thanks for the reply I looked at forums Here is what I found I may be interpretinng this incorrect but http://www.therangerstation.com/tech_library/Seats.shtml One other word of warning Ranger Standard-cab, Ranger Supercab and Bronco II's all have different floor pan profiles and so use different seat tracks, so if you want to put buckets or a split-bench into a std cab Ranger you must get your seat tracks out of a std cab Ranger. |
porschetub |
Aug 10 2015, 01:09 AM
Advanced Member Group: Members Posts: 4,705 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
If the Ranger is like any other truck, the floor mounts are the same, so the buckets n brackets from the same era should bolt in. A Ranger forum would tell you for sure. $200 should get you most of the bench recovered. Shop around a little. thought this was a forum for 914 cars (IMG:style_emoticons/default/WTF.gif) ,cheers |
thelogo |
Aug 10 2015, 07:58 AM
[quote name='porschetub' date='Aug 10 2015, 12:09 AM' post='2221295']
[quote name='Chris914n6' post='2221251' date='Aug 10 2015, 04:02 PM'] If the Ranger is like any other truck, the floor mounts are the same, so the buckets n brackets from the same era should bolt in. A Ranger forum would tell you for sure. $200 should get you most of the bench recovered. Shop around a little. [/quote] thought this was a forum for 914 cars (IMG:style_emoticons/default/WTF.gif) ,cheers [/quote Look mate I come here for advice and ranger forum s suck So if your not gonna help out Then piss off Oye |
boxstr |
Aug 10 2015, 04:57 PM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
I bought a pair leather seat from a later tbird and used one in the passenger position
It worked okay. The reason was that the original passenger seat was trash I never got around to mounting the other seat, these are separate bucket with seat heaters and electric back and forth action I still have the one drivers side seat available. If wanted it is big and heavy $150. Craig at CAMP |
boxstr |
Aug 10 2015, 04:58 PM
This was in a 2001 xlt extended cab ranger.
Ccl |
thelogo |
Aug 10 2015, 08:28 PM
I bought a pair leather seat from a later tbird and used one in the passenger position It worked okay. The reason was that the original passenger seat was trash I never got around to mounting the other seat, these are separate bucket with seat heaters and electric back and forth action I still have the one drivers side seat available. If wanted it is big and heavy $150. Craig at CAMP Hey yeh it's a 2001 And did your seat from the t bird bolt right in. ??? |
Chris914n6 |
If the Ranger is like any other truck, the floor mounts are the same, so the buckets n brackets from the same era should bolt in. A Ranger forum would tell you for sure. $200 should get you most of the bench recovered. Shop around a little. thought this was a forum for 914 cars (IMG:style_emoticons/default/WTF.gif) ,cheers (IMG:style_emoticons/default/WTF.gif) with the (IMG:style_emoticons/default/WTF.gif) I didn't start the post, which should have been in the sandbox for being off topic. 914 content--- My Nissan truck's bench and buckets are bolt in swaps. My truck brought home from the wrecker the Nissan engine in my 914, plus towed it a few times, and a few others, and parts. Thus this thread is six degrees of Kevin Bacon (IMG:style_emoticons/default/beer.gif) thelogo- I didn't get too far into it but it looks like you have a few options. It might surprise folks where the OEMs decide to cut engineering costs. |
dangerranger01 |
Aug 10 2015, 09:05 PM
Member Group: Members Posts: 145 Joined: 12-August 05 From: Boring, Oregon U.S.A. Member No.: 4,578 Region Association: None |
You are right. Only standard cab seats fit into standard cab rangers. Extended cabs won't fit in yours. The issue is that the seat rails are riveted to the seats themselves.
Is your model an XL? I went with Edge model seats and they are sooooo much more comfortable. I also heard of guys dropping in mustang seats but heard they lost some room. I am 6'-2" so I need all i can get. If i were you, i would try to find standard cab Edge model seats, or just get seat covers. Not worth the hassle of the air bag sensors to swap in some shitty aftermarket "race" seat. Source: I daily a 2001 standard cab Ranger for the last 11years. |
porschetub |
Aug 10 2015, 10:27 PM
[quote name='thelogo' date='Aug 11 2015, 01:58 AM' post='2221373']
[quote name='porschetub' date='Aug 10 2015, 12:09 AM' post='2221295'] [quote name='Chris914n6' post='2221251' date='Aug 10 2015, 04:02 PM'] If the Ranger is like any other truck, the floor mounts are the same, so the buckets n brackets from the same era should bolt in. A Ranger forum would tell you for sure. $200 should get you most of the bench recovered. Shop around a little. [/quote] thought this was a forum for 914 cars (IMG:style_emoticons/default/WTF.gif) ,cheers [/quote Look mate I come here for advice and ranger forum s suck So if your not gonna help out Then piss off Oye [/quote] Ok then put in in the off topic forum,then clean up your mouth,thank you for charming response and I don't think you have many mates,cheers. |
Lo-Fi Version | Time is now: 8th June 2024 - 03:34 AM |
