Wipers now working....but, very slow |
porschetub |
Aug 15 2015, 04:37 PM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Wipers and electric washer working but wiping action is slow,my plan is to check voltage to motor and other wiring checks to start with.
Linkages all seem to be free moving and very smooth,I'am thinking maybe the motors gunked up ?,is this common with these cars?,I have cleaned other wiper motors to good result. Suggestions please,thanks. |
914Sixer |
Aug 15 2015, 07:31 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
You are right on the money. Take motor off and check rack movement. Most have 40 yr old white gum grease. Be EXTRA careful with little C-clip at the top of the stem.
HalfMoon |
Aug 15 2015, 07:33 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
Try using emory cloth on fuse 8 and it's holders. You'd be suprised.
porschetub |
Aug 16 2015, 12:31 AM
You are right on the money. Take motor off and check rack movement. Most have 40 yr old white gum grease. Be EXTRA careful with little C-clip at the top of the stem. Cheers 914sixer ,have close to full voltage there ,losing around 1 volt @ the motor so that not an issue I don't think? Thanks also halfmoon,checked that and replaced fuse any way ,had around 12v there. Found the outer gland nuts on the wiper cowl loose from when it was painted I guess,that made some differance. Took off RH side wiper arm off and ran it faster,really good enough to think thats all it has on the second speed. So wiper drive out? any clever tips on removal ?,first time for me,thanks. |
Lo-Fi Version | Time is now: 1st June 2024 - 11:11 AM |
