how to bypass wiper switch? |
jimkelly |
Aug 17 2015, 07:27 PM
for some reason my wipers do not function from controls on the column. so to pass inspection, I was thinking of wiring them just enough to get one speed.
which wires would make a circuit to run my wipers at one speed? Attached image(s) |
914ltd |
Aug 18 2015, 06:26 AM
Member Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
Hi Jim, the terminals closest and furthest from the wiper motor transmission will work. The other 2 terminals are used to park the wipers. Brad
jimkelly |
Aug 18 2015, 01:04 PM
i will pick up 3 relays, as i need to run a temporary circuit for my horn too. and i want to put on on my starter too, mcmark style. maybe though i might use a ford heavy duty relay for this? Attached image(s) |
porschetub |
Aug 18 2015, 10:05 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
for some reason my wipers do not function from controls on the column. so to pass inspection, I was thinking of wiring them just enough to get one speed. which wires would make a circuit to run my wipers at one speed? Jim did you check to see if the male pins coming from the switch are all there ?I found 2 of mine had pushed through the wire retainer,its a pain to fix but will get you going,just an idea. |
jimkelly |
Aug 20 2015, 08:21 AM
probably not my problem. these things were all working before i switched fuse boxes and fried some wires. i think the only 2 things not working now are, horn and wipers. are they on same circuit?
just found this thread and seems they are? http://www.914world.com/bbs2/index.php?sho...p;#entry1906897 >> does anyone know if the horn/wiper relay is the typical black round plastic type? seems the answer is yes. i found this pic. if i am lucky, i will simply need to replace my horn relay. Attached image(s) |
Lo-Fi Version | Time is now: 4th June 2024 - 10:13 PM |
