WTB grease caps, need over type grease/dust cap for 911 hub 58mm |
Alapone |
Aug 18 2015, 08:35 AM
Member Group: Members Posts: 105 Joined: 4-April 13 From: Nj Member No.: 15,734 Region Association: None |
Hello all,
I need to buy a set of "over type" grease caps in good condition. Just to be clear these are for 911 boge struts going to be used for a conversion. -There are two main types of these, ones that fit in the hub and ones that fit over the hub with an interference fit. I need the latter type. -They should have a 58mm diameter and the shape should be wider at the opening than at the closed side. Please let me know what you have. I will need pics on this as I recently purchased a set of the wrong caps. Thanks, Andrew |
Alapone |
Aug 26 2015, 05:19 AM
Hello all, I need to buy a set of "over type" grease caps in good condition. Just to be clear these are for 911 boge struts going to be used for a conversion. -There are two main types of these, ones that fit in the hub and ones that fit over the hub with an interference fit. I need the latter type. -They should have a 58mm diameter and the shape should be wider at the opening than at the closed side. Please let me know what you have. I will need pics on this as I recently purchased a set of the wrong caps. Thanks, Andrew I found a set on ebay no longer need these |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:48 PM |
