Rear shock/Spring installation help, Does it matter if the spring is in a certain position? |
Dredwin |
Aug 22 2015, 11:21 PM
Member Group: Members Posts: 71 Joined: 21-December 13 From: Colorado Springs Member No.: 16,783 Region Association: Rocky Mountains |
So I replaced my rear shocks and the Haynes manual said to align the lower spring mount with the hole in a certain location. My old shocks and new shocks mount didn't have a hole.
Does it matter how the spring is mounted? The original springs had a paint mark on it, does that paint mark face the outside or another direction? thank for the help |
914Sixer |
Aug 23 2015, 06:40 AM
914 Guru Group: Members Posts: 8,902 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
What kind of shocks did you use? They all should have a drain hole that goes to the inside. You probably should have replaced the 40+ year old springs too. If the springs had just one dot not three, they were the early WEAK springs.
Dredwin |
Aug 23 2015, 12:18 PM
What kind of shocks did you use? They all should have a drain hole that goes to the inside. You probably should have replaced the 40+ year old springs too. If the springs had just one dot not three, they were the early WEAK springs. Bilstein shocks. After replacing the shocks, I realized I needed springs. I bought springs but didn't want to guess at the installation. The original springs had 3 marks. No hole on the old Bilstein or the new one. I'll try and look again. Do you think the marking on the springs go on the outside? |
914Sixer |
Aug 23 2015, 12:22 PM
Markings on new springs are just information only. Bilstein mounts are flat not cupped like other ones but the dip needs to be to the inside to drain. I went out and took some pictures to help.
Attached image(s) |
rgalla9146 |
Aug 23 2015, 12:30 PM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
The paint marking on the springs indicates spring strength (and application, IIRC)
Yellow for a 6 ? Rotation is not important other than that both ends are properly seated in their cups. On the bottom the coil ends right where the hole is. At least with OE bottom seats. |
Lo-Fi Version | Time is now: 7th June 2024 - 03:19 AM |
