74 2.0 fuel pump relay, Where is it |
9fourteen14 |
Aug 23 2015, 09:30 PM
PORSCHE LUVA Group: Members Posts: 135 Joined: 5-July 15 From: boston Member No.: 18,920 Region Association: North East States |
Have a 74 2.0 and need to know WHERE is the fuel pump relay?
Thank you |
Stacks914 |
Aug 24 2015, 12:47 AM
Member Group: Members Posts: 183 Joined: 1-April 15 From: Omaha, ne Member No.: 18,582 Region Association: None |
It's in the relay board behind the driver in the engine compartment. You'll see three or four small round relays in a staggered order on the left side. If you look at it from the back of the car it is the third one from the back. I just did this and mine turned out to be a faulty #14 wire coming in from the harness. Good luck!
Stacks914 |
Aug 24 2015, 12:51 AM
Here yea go. Fuel pump relay is 75
Attached thumbnail(s) |
9fourteen14 |
Aug 24 2015, 08:05 AM
It's in the relay board behind the driver in the engine compartment. You'll see three or four small round relays in a staggered order on the left side. If you look at it from the back of the car it is the third one from the back. I just did this and mine turned out to be a faulty #14 wire coming in from the harness. Good luck! thank you so much I am going out this morning to check this out. stay tuned.. I will let ya know what is the outcome. BTW: why did you change yours? 914luva |
9fourteen14 |
Aug 24 2015, 08:06 AM
Stacks914 |
Aug 24 2015, 11:23 AM
No problem! I didn't change mine the power wire #14 turned out to be faulty so I just ran another. And I did that becuase the fuel pump was not coming on. Alot of time figuring that out. I started saying "after I get this fixed I will just get another opportunity to find another solution" (IMG:style_emoticons/default/biggrin.gif)
9fourteen14 |
Aug 25 2015, 10:37 AM
No problem! I didn't change mine the power wire #14 turned out to be faulty so I just ran another. And I did that becuase the fuel pump was not coming on. Alot of time figuring that out. I started saying "after I get this fixed I will just get another opportunity to find another solution" (IMG:style_emoticons/default/biggrin.gif) Hey Stacks, I really appreciate it.... I did find the 4 relays. thank you... I tried to attach a picture of this area in the engine bay but the server is NOT being good to me lately. anyway.. on with the test.... stay tuned... I am determined to get to the heart of this matter..... I want to drive my car. 914 luva |
Lo-Fi Version | Time is now: 7th June 2024 - 05:09 AM |
