914guy |
Newbie ![]() Group: Members Posts: 46 Joined: 11-April 03 From: Fairfax VA Member No.: 561 ![]() |
Does anyone have a procedure to grease the wheel bearings? Does it involve removing the caliper, or is there a way to work around having to do that?
Thanks, ~Eric |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
You can only service the smaller outer bearing if you do not remove the caliper. I'd just remove the caliper and get them both out of the way.
Wear gloves!!! That grease is nasty (IMG:style_emoticons/default/wacko.gif) |
Lawrence |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None ![]() ![]() |
A guy nicknamed as Dirty Dan used to sell some very nice blue CV/bearing grease. I haven't heard from him lately, but I bought two quarts, and it was good stuff.
-Rusty Time for dinner (IMG:style_emoticons/default/chowtime.gif) |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Take everything apart and clean all the old grease out. Install with new grease ( I like that red stuff I found) and seals. How old are the bearings? I just as soon replace them if I don't know how old they are since they are cheap.
Seems like most 914's front wheel bearings are set too loose or worn out. They shouldn't go clunk when you push/pull on the tire. Geoff (IMG:style_emoticons/default/calvin.gif) (IMG:style_emoticons/default/smash.gif) |
Lawrence |
Like the new smilies, Geoff? (IMG:style_emoticons/default/smoke.gif)
MarkV |
Fear the Jack Stands ![]() ![]() ![]() Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None ![]() |
Lawrence |
Bleyseng |
Yeah (IMG:style_emoticons/default/stones.gif) , I just saw them!
(IMG:style_emoticons/default/lol3.gif) geoff |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
when i did new rotors, i bough new bearings from FLAPS. used castrol wheel bearing grease. (IMG:style_emoticons/default/chatsmiley.gif)
i like the new smilies |
tod914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 ![]() |
what exactley are races? I understand they are in the hub and the wheel bearings pop into them???
Do they need to be replaced when u do wheel bearings? And do the kits include them? |
914Timo |
******* ![]() ![]() ![]() Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe ![]() |
QUOTE Do they need to be replaced when u do wheel bearings? And do the kits include them? When you do bearings..... oh, I am not sure if I understand, but if you are going to grease them, you dont need to remove them. If you are going to chance the bearings, you have to chance them. The bearing consist of two rings and balls or rollers between them. The races are the outter ring of the bearing. I hope someone can explain better what the races are. Kits usually do include them. |
tod914 |
That makes alittle more sence. I was confused when I read that in the book. The shop book was saying that the races need to be pressed on by a shop. Or is it easy enough to do yourself?? Im totally ignorant on this so bear with me.
Part Pricer |
Believe everything I post ![]() ![]() ![]() Group: Benefactors Posts: 1,825 Joined: 28-December 02 From: Danbury, CT Member No.: 35 ![]() ![]() |
You thought you were confused before...we're just getting started.
Timo is right, the race is the outer ring of the bearing. This is the part that gets seating into the rotor. Can you do it yourself? Sure, with the proper tools and patience. If you look in the Haynes manual, it tells you to install the races using a "soft drift". When I read that I thought, "WTF is a drift and where do I find a soft one?" Well, when Chris and I did my bearings, he had a piece of aluminium pipe that was the same size as the race. The idea is that you want to use something that is softer than the race to push it into place so that you don't damage the race itself. A couple of smacks on the aluminum pipe with a mallet and the race was in place. If you've got a shop nearby, it might be worth a couple of bucks to take the rotors and races to them to have them pressed in. You could probably just go around to the side door with a six-pack in hand and get them done real quickly. |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
QUOTE(Lawrence @ Jun 9 2003, 02:47 PM) A guy nicknamed as Dirty Dan used to sell some very nice blue CV/bearing grease. I haven't heard from him lately ... Dan Petchel - posts to the 914 Rennlist group from time to time, i'm sure you'll find something from him in the archives. New Jersey area, not too far from me, actually. reputed to be one of the better Targa top restorers, i may have to look him up one of these years ... |
tryan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 553 Joined: 22-January 03 From: smokey mountains gatlinburg tn Member No.: 184 ![]() |
leslie tools makes a pretty cool aparatus for greasing up a bearing, but a blob in your palm works just as well. be sure to remove all the old grease from the hub. mixing different types is a no-no. just take a good look at the old races. if they are not pitted or blued, leave them alone.
if you are going to reuse your old bearings, clean them and dry them. put a golf ball size blob in your left hand. scrap the opened/large side of the bearing across the edge of the grease to push it into the cage. when fresh grease come out of every hole you are done. |
cgnj |
Senior Member ![]() ![]() ![]() Group: Members Posts: 678 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None ![]() ![]() |
QUOTE Dan Petchel - posts to the 914 Rennlist group I've met Dan. Friendly and knowlegeable. I stopped by his house Saturday and gave him some small parts for his 73 restoration (neve know when you'll need a favor). He is also having a six prepped for racing. Warning: A visit to his house will result in a serious case of car, tool, and part envy. Carlos |
tod914 |
Does he still have that green 6 sitting in his garage?
I was down there 3 years ago for some parts. Nice little setup he has there. |
cgnj |
Tod,
That's the car that being prepped. Carlos |
GWN7 |
King of Road Trips ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region ![]() |
When repacking bearings, take them out, wipe off the old grease with rags, hub too. Wash the bearing and hub with solvent. About 1" of solvent in a old coffee can & paint brush will do. let dry, do not use air to blow them dry, just pat and shake in rags. Check for "Blueing" or wear spots. If found, replace. Or load into this gizzmo (about $6 FLAPS).
Attached image(s) ![]() |
tod914 |
what is that device that the bearing packer attaches too?
Lo-Fi Version | Time is now: 12th July 2025 - 11:37 AM |
