Taking off the steering wheel hub?, How is this done? |
boxsterfan |
Sep 15 2015, 02:10 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
How do I get this part off?
Attached thumbnail(s) |
era vulgaris |
Sep 15 2015, 02:15 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
Put the steering wheel back on without the horn button. Grab one of the spokes in the steering wheel to leverage against your socket wrench. Also if you have one of those "club" anti theft thingies, attach it to the steering wheel for extra leverage.
SirAndy |
Sep 15 2015, 02:39 PM
Resident German Group: Admin Posts: 41,682 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
How do I get this part off? Remove the center nut from the shaft (27mm if i recall correctly), make sure you also get the large washer out from under the nut, then grab the hub and pull it off. Easier with the wheel still attached to the hub ... (IMG:style_emoticons/default/smile.gif) |
boxsterfan |
Sep 15 2015, 03:26 PM
Thanks guys. I'll try pulling harder. Perhaps I can pull on it hard enough that I solve the problem of getting my rear window out. (IMG:style_emoticons/default/smile.gif)
turk22 |
Sep 15 2015, 03:58 PM
Treetop Flyer Group: Members Posts: 735 Joined: 27-July 12 From: Cincinnati OH Member No.: 14,725 Region Association: Upper MidWest |
when your front lip starts bleeding, your pulling hard enough! (IMG:style_emoticons/default/av-943.gif)
AZ914 |
Sep 15 2015, 04:36 PM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
Yeah, you may want to wear a helmet.
I've actually used a hub type puller.. if you can get something for it to grab onto, it worked to at least 'break it free'. |
Dave_Darling |
Sep 15 2015, 04:44 PM
I've found that leverage and wiggling can move stubborn parts. I'd probably put the wheel back on the hub, loosen the retaining nut (but don't remove it!!) and then grabbing the outer edge of the wheel at 3 and 9 o'clock and pulling on each side alternately.
--DD |
porschetub |
Sep 15 2015, 11:49 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I've found that leverage and wiggling can move stubborn parts. I'd probably put the wheel back on the hub, loosen the retaining nut (but don't remove it!!) and then grabbing the outer edge of the wheel at 3 and 9 o'clock and pulling on each side alternately. --DD True Dave but has someone wound up the nut with the wrong spline on the wheel adaptor...seen it before. Agreed that the wheel needs to be on there to get it moving however. |
Lo-Fi Version | Time is now: 12th June 2024 - 06:28 PM |
