FS: 75 2.0 engine/trans/ecu, And other parts |
Stacks914 |
Sep 15 2015, 06:37 PM
Member Group: Members Posts: 183 Joined: 1-April 15 From: Omaha, ne Member No.: 18,582 Region Association: None |
Selling 75 2.0 engine and side sift trans. Engine DOES NOT run I could get it to start and run with starting fluid. Then it seemed to be running on one cylinder. Anyway I got busy and am going to use the car for other another project. Will not be using it or trans. I do not know what it will take to get it running. Trams I was told is good but bought car as non running. This still has the d jet system on it and will be including all of the stuff the engine needs to run. Basically I am including everything in the engine bay of the car minus the battery and relay board. $1000 or make me an offer. I am in Omaha ne 68137 you pay shipping!!!
I also have tons of parts suspensions for two cars brand new rear brakes. One body that I will cut up. One set of working pop up lights. And a bunch of other parts. I have both 72 and 75 front and rear bumpers. If you need anything let me know I will send pics and a more than far price |
CSoso |
Sep 15 2015, 09:14 PM
Over-analyzing one mistake at a time... Group: Members Posts: 24 Joined: 29-August 15 From: Jackson, Michigan Member No.: 19,114 Region Association: Upper MidWest |
hi! Do you have a front sway bar, mounts, arms and links? I would prefer a 19 mm bar but the other might work. Thanks!
Stacks914 |
Sep 15 2015, 10:32 PM
Yes the 75 has a stock front sway bar. I will have to look into the size.
bdstone914 |
Sep 15 2015, 10:38 PM
bdstone914 Group: Members Posts: 4,533 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Stacks914 |
Sep 15 2015, 10:39 PM
cool thnk you!!
Lo-Fi Version | Time is now: 4th June 2024 - 05:16 AM |
