'74 - '75 MPS Compatibility, Will an MPS from a '75 2.0 work on a '74 2.0? |
KELTY360 |
Sep 16 2015, 12:23 PM
914 Neferati Group: Members Posts: 5,037 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
Thread title says it all.
Bob L. |
Sep 16 2015, 12:30 PM
Senior Member Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
It depends on the ECU you have.
http://members.rennlist.com/pbanders/DJetP...m#Compatibility |
JeffBowlsby |
Sep 16 2015, 12:38 PM
914 Wiring Harnesses Group: Members Posts: 8,537 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Check the chart again, all 74-76 2.0L use the same 043 MPS.
KELTY360 |
Sep 16 2015, 12:39 PM
Thanks both of you. That helps a lot.
greenie |
Sep 17 2015, 09:17 AM
Senior Member Group: Members Posts: 873 Joined: 26-October 04 From: Trinidad Member No.: 3,013 Region Association: Pacific Northwest |
Check the chart again, all 74-76 2.0L use the same 043 MPS. Thank you Jeff ! After installing the MPS from a 1975 car my car runs entirely different. I always thought that the MPS held vacuum or failed, this is not the case, I think I've been fighting a slow leak through the MPS for years. For the first time in a long while my air bleed screw at the throttle body actual works! after installing the new MPS the idle was at 1500RPM, a twist of the screw brought it down to 1K. My throttle response is smooth and the car runs fantastic. |
Lo-Fi Version | Time is now: 12th June 2024 - 11:18 PM |
