Front sway bar, Adjustment advice |
DavidSweden |
Sep 19 2015, 04:18 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
After replacing the front bushings and rear wheel bearings I took the car and had all 4 wheels aligned, it has made a major difference to the handling. I have also installed an adjustable 22mm Weltmeister front sway bar.
Question: I have the sway bar adjusted to the middle stiffness adjustment. How can I tell if its properly adjusted? Thanks |
Mike Bellis |
Sep 19 2015, 05:08 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
That depends on your driving style. End of arm = less stiff. Closer to bar = more stiff.
Lo-Fi Version | Time is now: 12th June 2024 - 08:35 PM |
