Alternative Ventalation, Venting on venting |
forrestkhaag |
Sep 21 2015, 07:24 PM
Alternative Ventilation
Has anyone perfected a simple interior ventilation system once the hvac is blanked off and deleted in an early 914? My goal is to have a two-sided control total mechanical system to shove some fresh air into the cabin when the windows are up / one side or the other or both / not to the windshield but to the lower cabin only. In SoCal, we have no humidity, no rain, no inclement weather, not one single bug, no latent dust (unless behind a 6…, and no particulate allergens or pollen, so I am thinking that the system will be an add-on to my tow bar hitch receiver tubes subtly located thru the front bumper and in to the front trunk bay… but…. from there, things get difficult due to this big bulbous thing called a fuel tank….. I know from many removals and insertions of the tank that there is no room for two flexible tubes to make their way thru the tank cavity unless we agree to go electric. So, maybe someone has another route for two individually mechanically controlled vent tubes to the front cabin. Of course, the Germans used the cowl vent to drain rain and to power up ventilation to the cabin and windshield. I am looking for a simple alternative.. Any suggestions are appreciated. |
SirAndy |
Sep 21 2015, 07:30 PM
Resident German Group: Admin Posts: 41,680 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
While this is from an aftermarket heater unit, the air routing over the tank would work in your case.
(IMG:style_emoticons/default/smile.gif) (IMG:http://www.914world.com/bbs2/uploads/post-179-1422730038.jpg) |
914_teener |
Sep 21 2015, 07:35 PM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I don.t get why the stock fresh air intake won.t work?
It is simple but a PITA to take apart and reinstall. |
914Mike |
Sep 22 2015, 12:11 AM
Member Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
I have run oil lines under the tank through the little tunnel inside the wheel arch. Starts at the gas tank bulkhead and runs down to the footwell. Poke a few holes, add some tubes, cool your feet at least. The back side tends to be rusty anyway, very easy to perforate...
jim_hoyland |
Sep 22 2015, 05:07 PM
Get that VIN ? Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
How about a roof vent ?
Attached image(s) |
Kansas 914 |
Sep 22 2015, 05:24 PM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
i am thinking about a bilge blower to replace the fresh air blower up front since my car has Kerry Hunter headers and no heat. It would be nice to have real forced air through the vents.
http://www.amazon.com/Rule-140-Marine-Blow...h/dp/B000O8AZ8K |
76-914 |
Sep 22 2015, 06:35 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I don.t get why the stock fresh air intake won.t work? It is simple but a PITA to take apart and reinstall. I fart with more force than that anemic OEM vent system puts out. (IMG:style_emoticons/default/dry.gif) Another BIG + when one does a water cooled conversion and AC (IMG:style_emoticons/default/biggrin.gif) |
Chris914n6 |
Sep 22 2015, 06:59 PM
Jackstands are my life. Group: Members Posts: 3,338 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I read and I got confuzed...
The cowl vent allows a good amount of air to pass into the cabin when restrictions are removed. As in the air box is removed. Or... air ducts/blower in the back passing thru the longs into the cabin, or piped into the side vents. Or take apart the flapper boxes and block off the windshield path, leaving the side vents and floor opening. |
914_teener |
Sep 22 2015, 07:22 PM
I don.t get why the stock fresh air intake won.t work? It is simple but a PITA to take apart and reinstall. I fart with more force than that anemic OEM vent system puts out. (IMG:style_emoticons/default/dry.gif) Another BIG + when one does a water cooled conversion and AC (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/flag.gif) Not sayin use the little fart fan that isthe OEM.....use the same entry and exit points and higher output fans. I have no comment about the volocity of your farts Kent.... |
7TPorsh |
Sep 22 2015, 07:30 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
i am thinking about a bilge blower to replace the fresh air blower up front since my car has Kerry Hunter headers and no heat. It would be nice to have real forced air through the vents. http://www.amazon.com/Rule-140-Marine-Blow...h/dp/B000O8AZ8K oooh, I like that! Run one through the front for cool air and one through an oil cooler for hot. |
barefoot |
Sep 22 2015, 07:43 PM
Senior Member Group: Members Posts: 1,282 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
i am thinking about a bilge blower to replace the fresh air blower up front since my car has Kerry Hunter headers and no heat. It would be nice to have real forced air through the vents. http://www.amazon.com/Rule-140-Marine-Blow...h/dp/B000O8AZ8K I installed one like this bilge blower in my boat to purge the motor cavity. The stock 914 vent blower puts out more air. |
914_teener |
Sep 22 2015, 07:49 PM
i am thinking about a bilge blower to replace the fresh air blower up front since my car has Kerry Hunter headers and no heat. It would be nice to have real forced air through the vents. http://www.amazon.com/Rule-140-Marine-Blow...h/dp/B000O8AZ8K I installed one like this bilge blower in my boat to purge the motor cavity. The stock 914 vent blower puts out more air. There is velocity and volume...... Good point. |
Krieger |
Sep 22 2015, 08:26 PM
Advanced Member Group: Members Posts: 4,728 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
There was this a few years back from a post by Trekkor.
Attached image(s) |
Larmo63 |
Sep 22 2015, 09:24 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
Forrest's car is early, no dash vents.
screenguy914 |
Sep 23 2015, 11:59 AM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
Bilge blowers are efficient and relatively inexpensive. Racers sometimes use them to duct forced air to help cool brake components and fluid coolers.
However, depending on their placement, they may be excessively noisy when used to source cabin air. I use a 4" Spal fan to help evacuate trunk air from a front oil cooler. However, its sound isn't noticeable during normal operation unless the engine is OFF. Sherwood |
Lo-Fi Version | Time is now: 10th June 2024 - 02:44 PM |
