Autocross tire squeal, Not the good kind |
worn |
Sep 24 2015, 08:55 PM
can't remember Group: Members Posts: 3,162 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
After a spirited run around and over the cones I noticed a rubber smell persisting. This week driving to work I heard a squeal. Today it seems the right rear tire is rubbing the inner fender where the box projects towards the wheel. The camber has become more pronounced and is visibly tipped in at the top of the wheel. Tires are 205s, but they cleared before. Clearly something has changed, and I suspect that in fact it changed during the autocross. Can you help me with ideas? The suspension console looks ok but the car has rust separating much of the firewalls from the floor at the rear. Car actually feels solid with no door gap issues.
Thanks |
mepstein |
Sep 24 2015, 09:02 PM
914-6 GT in waiting Group: Members Posts: 19,312 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I'll bet the suspension console is failing. Classic issue for these cars. Bob just noticed his going on huey after a spirited run at the track. They fail from the inside out.
ConeDodger |
Sep 24 2015, 09:08 PM
Apex killer! Group: Members Posts: 23,610 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I'll bet the suspension console is failing. Classic issue for these cars. Bob just noticed his going on huey after a spirited run at the track. They fail from the inside out. (IMG:style_emoticons/default/agree.gif) ^^^ |
JamesM |
Sep 24 2015, 10:31 PM
Senior Member Group: Members Posts: 1,915 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
check the bushings in the trailing arm first
cary |
Sep 24 2015, 11:12 PM
1. console is cracked
2. alignment settings came loose I bet money on #1. BTDT. The kids went airborne over a parking lot curb at an autocross in Montana. Within a month the console was cracked. |
EdwardBlume |
Sep 24 2015, 11:40 PM
Do more of a closer inspection. hope its failed bushings but thats got more symptoms....
LowBridge |
Sep 25 2015, 06:22 AM
Member Group: Members Posts: 370 Joined: 10-August 15 From: Lunenburg, MA Member No.: 19,045 Region Association: North East States |
check the bushings in the trailing arm first (IMG:style_emoticons/default/agree.gif) jack the car up and you should notice that you can flex the wheel in and out. look at the pickup points and if they look fine then it's the bushings. you can get large amounts of movement from both problems and it's easy to tell which one it is. hopefully it's just bushing as that is the cheap fix. |
Chris Pincetich |
Sep 25 2015, 08:29 AM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
Pre-AX tech inspectors in my PCA zone typically grab a wheel and shake it very hard, rocking in and out. Not on all cars; they like to pick on old 914s since they break down and/or spew oil more often!! (IMG:style_emoticons/default/happy11.gif) This motion can reveal bad bearings or suspension bushings, because you will feel it. I would not try that with the car up on a jack or even jack stands. If you already know about lots of rust back there.... (IMG:style_emoticons/default/sad.gif)
Good luck (IMG:style_emoticons/default/beerchug.gif) |
worn |
Sep 25 2015, 09:04 AM
check the bushings in the trailing arm first Well, the votes are in and I will check it out. Matched my suspicions but it is always best to ask the world about these things. I will get back with a verdict in a day or two. It seems I am lucky if I can go two steps forward and one step back. I would say rust too, except I know the car pretty well and have fixed these issues on the conversion tub. I kinda think that the longs and console are better than that. But - rust not only is insomniac, but camouflaged at every turn. So, I know better than to guess. I wish the lift wasn't a half hour drive... Thanks one and all. Great support! |
mepstein |
Sep 25 2015, 11:20 AM
Jacking up the car and removing the wheel will let you check out the suspension console.
If it's too rusty to use a jack then it shouldn't be driven. |
JRust |
Sep 25 2015, 11:42 AM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Jacking up the car and removing the wheel will let you check out the suspension console. If it's too rusty to use a jack then it shouldn't be driven. (IMG:style_emoticons/default/agree.gif) I would bet suspension ear is cracked & more than half way & you'll be thanking your lucky starts. It's much nicer to catch it before it tears off completely |
worn |
Sep 25 2015, 03:44 PM
Jacking up the car and removing the wheel will let you check out the suspension console. If it's too rusty to use a jack then it shouldn't be driven. (IMG:style_emoticons/default/agree.gif) I would bet suspension ear is cracked & more than half way & you'll be thanking your lucky starts. It's much nicer to catch it before it tears off completely Thanks. I peaked underneath before I left for work. I had to drive my TR6 instead. It looks like either the inner bushing is gone, or the inner suspension ear has an ovalled hole. Or both. Wouldn't rule out cracks though. No major displacement of pieces. It is no way near too rusted to jack up. The jack points even work, but I rarely use them. If I do, instead of buying one of those round plates for the floor jack I use a tow hitch ball with the shank ground square to fit in the hole. No matter what angle I reach the jack point is steady. |
Cairo94507 |
Sep 25 2015, 04:08 PM
Michael Group: Members Posts: 9,820 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
On my 2nd Six I got very lucky. When the engine was out to straighten out some issues from the 3.0 CIS install, I was cleaning the engine compartment and underneath since it was so accessible and found the passenger side rear suspension mounting point cracked more than 1/2 way.
It was a lucky break as we had the engine already out so we addressed that by replacing that ear and also replaced the batter box at the same time as it had some rust holes. Back then it was only about $400 if I remember correctly. That even included respraying the engine compartment so it looked like new. The body shop was right behind my mechanic so we just rolled the car over to their shop. Once I saw the damage I was shaken up as I drive that card hard regularly through a 10 mile canyon road and can only imagine the crash if that ear had completely failed. |
EdwardBlume |
Sep 25 2015, 05:33 PM
My inner ear was cracked after 86K miles and 100% street use. Found it after an engine pull and prior to repaint.
worn |
Sep 26 2015, 04:40 PM
1. console is cracked 2. alignment settings came loose I bet money on #1. BTDT. The kids went airborne over a parking lot curb at an autocross in Montana. Within a month the console was cracked. OK, how much did you lose, or I winned? It is was the inner bushing, all squirmy and gone. Now I need new CV gaskets and to figure out what bushing to use! So to heal my heroic old car, what is considered the best solution. Needle bearings with automated greasing? Rubber inserts? Rubber stoppers with holes drilled? Or some sort of polymer like either Delrin or urethane? What do you guys like? My wife doesn't like riding in it anyway if that helps people make up their minds. Grippier tires and new bilsteins didn't delay this. |
worn |
Sep 26 2015, 04:43 PM
On my 2nd Six I got very lucky. When the engine was out to straighten out some issues from the 3.0 CIS install, I was cleaning the engine compartment and underneath since it was so accessible and found the passenger side rear suspension mounting point cracked more than 1/2 way. It was a lucky break as we had the engine already out so we addressed that by replacing that ear and also replaced the batter box at the same time as it had some rust holes. Back then it was only about $400 if I remember correctly. That even included respraying the engine compartment so it looked like new. The body shop was right behind my mechanic so we just rolled the car over to their shop. Once I saw the damage I was shaken up as I drive that card hard regularly through a 10 mile canyon road and can only imagine the crash if that ear had completely failed. Yeah. That is one reason I decided to reinforce the ears on my six conversion. My son had the car up on jack stands when I got home today, probably expecting to weld. Silly for us to have three welders a thirty minute drive from our lift... Thanks. |
worn |
Sep 26 2015, 04:50 PM
Jacking up the car and removing the wheel will let you check out the suspension console. If it's too rusty to use a jack then it shouldn't be driven. Thanks. It is really rusty in places, but the worm seems to have bypassed this spot at present. Someday I will pull the motor again to do what is right by that car, but right now it is the one that always delivers. Fer instance, I started tearing apart the motor for my 911 cause of the dilivar studs. Made progress there but would prefer to drive the 911. The six conversion moved ahead in that I think I have all the fuel lines tight. I silver brazed stainless in bad conditions, and had to redo. So, this one little 914 was the one that behaved reliably. |
cary |
Sep 26 2015, 11:53 PM
worn |
Sep 27 2015, 08:37 AM
I'd bet money on #1. I'll buy dinner when you make it out here one day. As I recall we could probably get dinner where you work (IMG:style_emoticons/default/laugh.gif) What do you use for bushings, or what do you think I should use? There seems to be a range of choices. |
cary |
Sep 27 2015, 09:08 AM
Here's what I plan to use.
http://www.elephantracing.com/suspension/r...berbushings.htm I had metal on metal on my tractors in Montana. LOL. |
Lo-Fi Version | Time is now: 6th June 2024 - 11:22 AM |
