Gas tank hole, ******Update****** |
jim_hoyland |
Oct 8 2015, 07:18 PM
Get that VIN ? Group: Members Posts: 9,313 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I found a #4 screw plugging a small hole in my gas tank. Can JB Weld be used to fill the hole ?
bahnzai |
Oct 8 2015, 07:29 PM
Member Group: Members Posts: 307 Joined: 26-July 06 From: Columbia, SC Member No.: 6,509 Region Association: South East States |
I have used it successfully on a rust through hole in the tank. I figured I was no worse off if it did not work. Not an elegant solution, but functional!
zipedadoo |
Oct 8 2015, 07:37 PM
Member Group: Members Posts: 135 Joined: 23-January 14 From: Arizona Member No.: 16,921 Region Association: None |
Don't do it if you have ethanol in your fuel. It will eat the jb weld. Search the web you will see it's true....(IMG:style_emoticons/default/smile.gif)
jim_hoyland |
Oct 8 2015, 07:55 PM
Anyone try the Permatex Repair Kit ?
r_towle |
Oct 8 2015, 08:20 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Dude, weld it.
Take it out, dump the fuel, fill it with water and weld it. Rich |
toolguy |
Oct 8 2015, 09:03 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Welding is difficult on rusted metal and often leads to a larger hole. .
clean the outside to bare shiny steel, use acid to clean and prep and solder a patch. |
Jeffs9146 |
Oct 8 2015, 09:13 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I welded mine! That was 2 years ago and all is good!
cary |
Oct 8 2015, 09:51 PM
Elliot Cannon |
Oct 8 2015, 10:26 PM
Clean up the rust, even if it means making the hole bigger. clean it up, fill it with water, weld a patch on it and paint it. Or I can give you a tank I have. (If Ihaven't tossed it). I'll see if it's still around tomorrow.
rick 918-S |
Oct 9 2015, 06:31 AM
Hey nice rack! -Celette Group: Members Posts: 20,471 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
There has to be a couple thousand tanks in storage in guys garages and sheds throughout the US. Why not post an ad in the classifieds and just get a replacement.
sb914 |
Oct 9 2015, 06:36 AM
Surf Guru Group: Members Posts: 4,314 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
Hey Jim, maybe you can get one this weekend at gnr , post wtb I'm sure someone will bring one.maybe Bruce has one.
jim_hoyland |
Oct 9 2015, 06:43 AM
Hey Jim, maybe you can get one this weekend at gnr , post wtb I'm sure someone will bring one.maybe Bruce has one. I believe there is one locally if needed; gonna take the tank down to Caps Radiator Shop in HB. Hate to replace; it is powder coated and in good condition other than the hole. It is not a rust hole. |
GregAmy |
Oct 9 2015, 08:13 AM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I've used the Balkamp/NAPA one successfully on my tank. Two years and still going strong.
Welding/soldering a patch is the "correct" way, of course. |
76-914 |
Oct 9 2015, 09:00 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I can silver solder or weld it up if you need. Kent
JamesM |
Oct 9 2015, 09:31 AM
Senior Member Group: Members Posts: 1,915 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
There has to be a couple thousand tanks in storage in guys garages and sheds throughout the US. Why not post an ad in the classifieds and just get a replacement. (IMG:style_emoticons/default/agree.gif) Tanks are super easy to pull, and with all the parts cars out there and limited need to replace gas tanks an undamaged one should be easy to come by. I have 3 extras at the moment, but I am sure you could find one locally without much effort. |
Mark Henry |
Oct 9 2015, 12:29 PM
On my bug I welded a surge tank right to the bottom of a main tank.
I never tested my welds , I epoxied the whole bottom of the tank. No leaks, but I only use real gas. |
913B |
Oct 9 2015, 12:49 PM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Contact Rotary'14 Robert I believe he has an extra that has already been POR-15 treated
jim_hoyland |
Oct 9 2015, 03:08 PM
Update: took it to the radiator shop and had it soldered. Asked the guy how much experience he had filling holes in gas tanks; turns out he is from Beruit Lebonon and filled hundreds of gas tanks that were hit by bullets. He said my hole wasn't even big enough to pass a BB... (IMG:style_emoticons/default/smile.gif)
Thanks for all the suggestions Attached image(s) |
Bartlett 914 |
Oct 9 2015, 04:42 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Update: took it to the radiator shop and had it soldered. Asked the guy how much experience he had filling holes in gas tanks; turns out he is from Beruit Lebonon and filled hundreds of gas tanks that were hit by bullets. He said my hole wasn't even big enough to pass a BB... (IMG:style_emoticons/default/smile.gif) Thanks for all the suggestions Tank looks nice. No wonder you didn't want to replace it |
JeffBowlsby |
Oct 9 2015, 06:02 PM
914 Wiring Harnesses Group: Members Posts: 8,524 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
What we all want to know Jim is how did that "friend of yours" happen to put the screw in the tank in the first place. That's the real story here.... (IMG:style_emoticons/default/happy11.gif)
Lo-Fi Version | Time is now: 1st June 2024 - 03:25 AM |
