Auxillary Fuse Block, 3 and 7 circuit |
Kansas 914 |
Oct 13 2015, 07:27 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
These look like just what I need on the '74 (It has a few accessories). Might not be a bad idea on all cars since there a re a few un-fused circuits in the original wiring.
http://www.jegs.com/p/JEGS-Performance-Pro...n=20151012email |
Kansas 914 |
Oct 13 2015, 07:36 AM
Items not fused (from my notes)
Ignition Switch Main Power Relay Fuel Injection ECU Started Headlamp Switch Fog Lamp Indicator Seat Belt Warning Buzzer Fasten Seatbelt Lamp |
Dave_Darling |
Oct 13 2015, 08:51 AM
It's usually a good idea to have your fuses close to the battery. That protects more of the wire. Someone here sold a small fuse block that would attach to the battery tray, and had good-sized fuses for the wires that were hooked to the battery (+) terminal. (Except for the big fat cable to the starter, of course.) If you're not trying to re-wire the car, that seems like a better way to go, because it requires minimal changes to the existing wiring.
--DD |
Harpo |
Oct 13 2015, 09:56 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I believe it was Tom that offered those kits
jeffdon |
Oct 13 2015, 12:08 PM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
At Rennsport, Jom Hoyland showed me the marine fuse block he installed near the battery. It protected the main 4 circuits coming of the battery, I believe.
Its got me thinking about doing this. But what about breakers instead of fuses. Do these trip quick enough: http://www.westmarine.com/buy/blue-sea-sys...ers--P006557607 |
barefoot |
Oct 14 2015, 07:08 AM
Senior Member Group: Members Posts: 1,279 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
At Rennsport, Jom Hoyland showed me the marine fuse block he installed near the battery. It protected the main 4 circuits coming of the battery, I believe. Its got me thinking about doing this. But what about breakers instead of fuses. Do these trip quick enough: http://www.westmarine.com/buy/blue-sea-sys...ers--P006557607 Or you can get fuzed blocks for 4, 6, & 8 fuzes from the same West marine source. |
AZ914 |
Oct 15 2015, 01:49 PM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
Mike,
I just saw the 'Tom' aux fuse block when looking thru PanelBilly's build thread: about 3 posts down: http://www.914world.com/bbs2/index.php?sho...8446&st=200 |
Kansas 914 |
Oct 15 2015, 02:44 PM
Mike, I just saw the 'Tom' aux fuse block when looking thru PanelBilly's build thread: about 3 posts down: http://www.914world.com/bbs2/index.php?sho...8446&st=200 Thanks Jason, very nice. I'm not sure how I missed that. |
Tom |
Oct 16 2015, 05:42 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
http://www.914world.com/bbs2/index.php?showtopic=141317
Above is my thread on the small 4 or 6 fuse fuseblock and my recommended way to install it. I quit putting them together and selling them because guys were installing them in a way that I thought was not good for the long run. The way I installed it keeps the wires from stressing the connections and insures there is no wear on the wires from rubbing. I was advised this could result in my getting involved in a legal issue. Feel free to use anything I have posted in my thread and if you have questions, I will answer them to the best of my ability. Tom |
porschetub |
Oct 16 2015, 12:42 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
These look like just what I need on the '74 (It has a few accessories). Might not be a bad idea on all cars since there a re a few un-fused circuits in the original wiring. http://www.jegs.com/p/JEGS-Performance-Pro...n=20151012email I'am running a 4 fuse Hella fusebox up under the dash for stereo headunit ,windscreen washer pump and aux heater demister,have run 30 amp rated cable to battery and sealed marine type fuse near battery,think that should be ok? I don't like stacking up spare aux wires into the factory fuseboard, maginal enough as is. |
Lo-Fi Version | Time is now: 4th June 2024 - 05:00 PM |
