| Teknon |
Mar 8 2005, 02:12 PM
The more I learn the dumber i think I am ![]() ![]() Group: Members Posts: 357 Joined: 10-August 04 From: Denver, Colorado Member No.: 2,505 Region Association: Rocky Mountains |
I picked up a bunch of parts and am trying to sort them out. I'm doing pretty good except for the throttle bodies.
I need to find out what these go to. 022 133 067 42mm 5 pins 022 133 067A 45mm 3 pins 039 133 067 45mm 4 pins I've search the net for two hours. Help (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) |
| mattillac |
Mar 8 2005, 02:52 PM
robots! ![]() ![]() ![]() Group: Members Posts: 536 Joined: 27-October 04 From: vallejo,ca Member No.: 3,020 |
| Teknon |
Mar 8 2005, 03:07 PM
039 133 067 45mm 5 pin
| Teknon |
Mar 8 2005, 03:09 PM
| Teknon |
Mar 8 2005, 03:10 PM
022 133 067 42mm 4 pin
| Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,326 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
I believe the first is 1.7; the second is 1.8; I know the third is 2.0. The 039 part number means 2.0. To me, three pins means 1.8 TB.
--DD |
| TheCabinetmaker |
Mar 8 2005, 04:03 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,365 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Not to dispute the wisdom of DD, buuuuutttt, The first pic looks to be from a 75 or 76 because of the extra return spring. I beleive that is a 2.0L from those years. Just went and checked mine. 022 133 067--75 2.0L
| Teknon |
Mar 8 2005, 04:31 PM
Curt, How many pin connectors are on your 022 133 067 ???? Is there an A after the numbers. Thanks for the info. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) |
| TheCabinetmaker |
Mar 8 2005, 04:51 PM
5 pins. No A
| Dave_Darling |
Mar 8 2005, 04:57 PM
Hey, Curt--all of the 2.0s except for the early 73s have the extra return spring.
If there's only one vacuum fitting on it (the one we see in the pic), it's a 74+ throttle body. If there are two, it could be mid-73 through 76; not all of the 74+ cars were missing the vacuum advance fitting. Any time you see a part with a VW part number starting "039", it's for a 2.0 liter. Almost always it's for an engine or engine-related part. --DD |
| TheCabinetmaker |
Mar 8 2005, 05:09 PM
I concede. Dave has spoken. but it is a 2L right?
Oh yeah, I wanna see ya at MUSR. I owe ya a 6 of newkie brown from last year. |
| SLITS |
Mar 8 2005, 05:27 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
PET 6 shows the numbers, except they all end in 62 not 67
Bosch CD doesn't recognize any of the numbers VW/AUDI EKT...numbers aren't even close What about numbers from the TPS itself...the black thingy? |
| Dave_Darling |
Mar 9 2005, 11:46 AM
Definitely. It even has the correct flange on the bottom to bolt down onto the top of the plenum; the other two have a different shape that bolts up to the side of the plenum.
I don't think that's going to happen, sadly. (See my "Guess What" post for the reason...) I hope you enjoyed the Newkie! (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) --DD |
| Allan |
Mar 9 2005, 11:57 AM
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I have the first one on my motor. (Well sort of, it's on the floor close to my motor) '76 2.0.
| SirAndy |
Mar 9 2005, 02:34 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,453 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
dave was talking about the order in which they were listed in the first post, you're talking about the order of the pictures he posted. simple mis-communication here ... dave's right (if you look at the order in which they were listed in the first post) (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
| mattillac |
Mar 9 2005, 03:56 PM
that looks the same as the TB on my 1975 2.0 fi d-jet, if that helps at all. |
Lo-Fi Version | Time is now: 5th March 2026 - 06:46 AM |
