Teknon
Mar 8 2005, 02:12 PM
I picked up a bunch of parts and am trying to sort them out. I'm doing pretty good except for the throttle bodies.
I need to find out what these go to.
022 133 067 42mm 5 pins
022 133 067A 45mm 3 pins
039 133 067 45mm 4 pins
I've search the net for two hours.
Help
mattillac
Mar 8 2005, 02:52 PM
Teknon
Mar 8 2005, 03:07 PM
039 133 067 45mm 5 pin
Teknon
Mar 8 2005, 03:09 PM
Teknon
Mar 8 2005, 03:10 PM
022 133 067 42mm 4 pin
Dave_Darling
I believe the first is 1.7; the second is 1.8; I know the third is 2.0. The 039 part number means 2.0. To me, three pins means 1.8 TB.
--DD
TheCabinetmaker
Mar 8 2005, 04:03 PM
Not to dispute the wisdom of DD, buuuuutttt, The first pic looks to be from a 75 or 76 because of the extra return spring. I beleive that is a 2.0L from those years. Just went and checked mine. 022 133 067--75 2.0L
Teknon
Mar 8 2005, 04:31 PM
| QUOTE (vsg914 @ Mar 8 2005, 04:03 PM) |
| Not to dispute the wisdom of DD, buuuuutttt, The first pic looks to be from a 75 or 76 because of the extra return spring. I beleive that is a 2.0L from those years. Just went and checked mine. 022 133 067--75 2.0L |
Curt, How many pin connectors are on your 022 133 067 ???? Is there an A after the numbers. Thanks for the info.
TheCabinetmaker
Mar 8 2005, 04:51 PM
5 pins. No A
Dave_Darling
Mar 8 2005, 04:57 PM
Hey, Curt--all of the 2.0s except for the early 73s have the extra return spring.
If there's only one vacuum fitting on it (the one we see in the pic), it's a 74+ throttle body. If there are two, it could be mid-73 through 76; not all of the 74+ cars were missing the vacuum advance fitting.
Any time you see a part with a VW part number starting "039", it's for a 2.0 liter. Almost always it's for an engine or engine-related part.
--DD
TheCabinetmaker
Mar 8 2005, 05:09 PM
I concede. Dave has spoken. but it is a 2L right?
Oh yeah, I wanna see ya at MUSR. I owe ya a 6 of newkie brown from last year.
SLITS
Mar 8 2005, 05:27 PM
PET 6 shows the numbers, except they all end in 62 not 67
Bosch CD doesn't recognize any of the numbers
VW/AUDI EKT...numbers aren't even close
What about numbers from the TPS itself...the black thingy?
Dave_Darling
Mar 9 2005, 11:46 AM
| QUOTE (vsg914 @ Mar 8 2005, 03:09 PM) |
| I concede. Dave has spoken. but it is a 2L right? |
Definitely. It even has the correct flange on the bottom to bolt down onto the top of the plenum; the other two have a different shape that bolts up to the side of the plenum.
| QUOTE |
| Oh yeah, I wanna see ya at MUSR. I owe ya a 6 of newkie brown from last year. |
I don't think that's going to happen, sadly. (See my "Guess What" post for the reason...) I hope you enjoyed the Newkie!
--DD
Allan
Mar 9 2005, 11:57 AM
I have the first one on my motor. (Well sort of, it's on the floor close to my motor) '76 2.0.
Mar 9 2005, 02:34 PM
| QUOTE (vsg914 @ Mar 8 2005, 02:03 PM) |
| Not to dispute the wisdom of DD, buuuuutttt |
dave was talking about the order in which they were listed in the first post, you're talking about the order of the pictures he posted.
simple mis-communication here ...
dave's right (if you look at the order in which they were listed in the first post)
Andy
mattillac
Mar 9 2005, 03:56 PM
| QUOTE (Teknon @ Mar 8 2005, 01:07 PM) |
| 039 133 067 45mm 5 pin |
that looks the same as the TB on my 1975 2.0 fi d-jet, if that helps at all.
