Subarugears Canbus Emulator |
914forme |
Oct 30 2015, 04:31 PM
I was (IMG:style_emoticons/default/drooley.gif) over Subarugears sight and noticed two new (IMG:style_emoticons/default/confused24.gif) items.
that would make a EZ swap a lot easier And this lovely device. Lets you see the oil level in the trans. |
Chris H. |
Oct 30 2015, 04:41 PM
Senior Member Group: Members Posts: 4,031 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Yeah that canbus emulator is $500 but their stuff is HIGH quality. Love the trans fluid level indicator. Didn't see that yet.
Smallcar has an interface board to emulate the top 7 fault codes for the sensors that won't be plugged in. Also helpful for later OBD 2 donor cars. Smallcar Interface board Reminds me of that big box tonyakavw made to emulate the sensors on his car. |
strawman |
Oct 31 2015, 09:29 AM
Senior Member Group: Members Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
That "Subaglass" gear oil level indicator sounds like a cool idea, but I can't figure out how/where it it mounted. Is it supposed to be TIG-ed in the case? It seems like a better alternative would be for Subagears to include the Subaglass in their "Subaplate" block-off plate ($200 incl worldwide shipping). Hmmm, I wonder if I can adapt a sightglass into my Bremar block-off plate...
Chris H. |
Oct 31 2015, 09:35 AM
I think there is a plug that can be removed on the side of the trans. There is a tapped threaded hole next to it conveniently.
Here's the details on how to install: Subaglass Great idea on the block off plate. I think that is Ian's next evolution. Definitely a better place for it. |
914forme |
Oct 31 2015, 12:56 PM
(IMG:style_emoticons/default/idea.gif) Figure out the proper size of the bung, tap it, then get one of these in the proper size.
M14 - M42 (IMG:style_emoticons/default/blink.gif) Done. I like the idea, that it should have been incorporated into the rear cover. But they do a lot of flipped ring, and pinion swaps, and this product could be used by all of their customers, and not just us 2WD mid engine guys. |
Lo-Fi Version | Time is now: 28th May 2024 - 01:50 PM |
