Clutch, trouble. I think. |
Elliot Cannon |
Nov 5 2015, 04:05 PM
My clutch pedal is not as smooth as it used to be. It kind of stutters when depressed. (Come to think of it so do I). Not sure if it's the tube or not. The clutch pedal engages just as high as before, just not as smooth. Well krap, the clutch cable probably needs changed anyway, so it looks like I'm back under it again. As nice as my 914 is, I am beginning to resent working on it. Is that a bad thing? Or am I just getting old(er). And no comments from you Kent. (IMG:style_emoticons/default/lol-2.gif) I know how to do this, I just needed to vent. (IMG:style_emoticons/default/mad.gif)
rhodyguy |
Nov 5 2015, 05:14 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Are you sure it isn't the pedal assem or the cable? How old is everything clutch related?
MartyYeoman |
Nov 5 2015, 05:39 PM
Senior Member Group: Members Posts: 1,520 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Better to put your hands on it now (IMG:style_emoticons/default/smash.gif) , then when your trying to cruise Peachy Canyon. (IMG:style_emoticons/default/hissyfit.gif)
Larmo63 |
Nov 5 2015, 05:41 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
Yes, you are getting crotchety.
r_towle |
Nov 5 2015, 05:46 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Release the cable from the clutch end.
Press the pedal and see if you can feel resistance. Maybe even put a bungee cord on the clutch end to create some resistance. It might be the fork, throw out bearing or pressure plate also.... Rich |
Elliot Cannon |
Nov 5 2015, 06:05 PM
Elliot Cannon |
Nov 5 2015, 06:07 PM
Release the cable from the clutch end. Press the pedal and see if you can feel resistance. Maybe even put a bungee cord on the clutch end to create some resistance. It might be the fork, throw out bearing or pressure plate also.... Rich Oh, man! Do NOT say fork, throw out bearing or pressure plate. I'm just not up for that one. (IMG:style_emoticons/default/smoke.gif) Although a new clutch would be nice. (IMG:style_emoticons/default/laugh.gif) |
76-914 |
Nov 5 2015, 06:19 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Remove the bolts from the shifter. turn the base 90 degrees then step on the pedal. You'll wee the tube move if that front weld gave way. (IMG:style_emoticons/default/poke.gif) Besides, you have a lift. How difficult can it be?
Lo-Fi Version | Time is now: 10th June 2024 - 03:04 PM |
