| TheCabinetmaker |
Nov 22 2015, 06:35 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,367 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Went turkey and fixins shopping today. Got home and noticed oil burning smell. Washed and polished the new paint and noticed a puddle of oil underneath. Oil dripping out the flywheel inspection hole. Half a pint maybe. Not a big deal, but it is my daily driver. I have a running 1.8 with dual 34s in a wrecked car. Plan is to remove 1.8, remove carbs, install a freshly painted set of 1.7 tins, plenum, and runners, move my fi items, minus ecu and mps, and install in my car. I'll have three days, and Brian, my right hand. I think we can do it. Won't be able to get started till Friday. Has to be done by next Monday. Can I do it?
Btw, it's a 2056, raby 9550 cam, with 70 plus thousand. It's definitely time for a refresh. |
| rick 918-S |
Nov 22 2015, 06:51 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,223 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
Sux, Just a thought could it be a oil galley plug coming loose?
| TheCabinetmaker |
Nov 22 2015, 06:52 PM
Drilled, tapped, and plugged.
| rjames |
Nov 22 2015, 07:12 PM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,440 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
The hardest part is balancing the transmission on the jack as you slide it out. That and navigating the CVs without knocking the balls out of the cages. You can complete the whole job in an afternoon if you've done it before.
If need be, Pelican's step by step guide on removing the tranny, which is included in their clutch replacement tech article, has all the info you need. Get new schnorr washers for the CVs as I don't think they are reusable. |
| TheCabinetmaker |
Nov 22 2015, 07:29 PM
Thanks Robert. I'm an old veteran at removing engines. I'll rebuild my engine later. Just doing a swap for now.
| stugray |
Nov 22 2015, 07:44 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
There's also the option that you slide off the tranny backwards, pull the FW and replace the seal.
Almost less work than dropping an engine, but barely... I would probably only do it with the FW hold tool for torqueing. But if youre just swapping the engine, I guess you can have the new one ready to go in before the old comes out. That's a bonus! (no surprise "while I'm in here" moments) |
| stugray |
Nov 22 2015, 07:49 PM
Oh, and the title reminded me of:
This penguin is driving his car along, and the car starts smoking so he pulls it into a garage. The mechanic agrees to look at it, so while he waits the penguin goes across the street to 7-11. He gets some ice cream and eats it while he waits but he gets it all over his face (penguins don't have hands...) He gets back to the garage and the mechanic says: "Well it looks like you just blew a seal" Penguin says: "Naw that's just a little ice cream" |
| TheCabinetmaker |
Nov 22 2015, 07:51 PM
That's the plan Stu. I have nothing else to drive just now. Truck is down too.
Unfortunately, I know what I'm gonna find. The rear main thrust bearing is worn down from the flywheel. I can hear the crank walking. |
| TheCabinetmaker |
Nov 22 2015, 07:59 PM
Lmao! That's funny stuff stu. Thanks. I needed a good laugh.
| porschetub |
Nov 22 2015, 08:16 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,040 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
That's the plan Stu. I have nothing else to drive just now. Truck is down too. Unfortunately, I know what I'm gonna find. The rear main thrust bearing is worn down from the flywheel. I can hear the crank walking. Bugger that's no good,can you remember what the RMS was ,on Pelican the Victor Reinz seals have been giving grief,I replaced mine for a genuine Porsche one,the VR one didn't fit as well as the genuine replacement ,this is on a -6 just asking.....? |
| TheCabinetmaker |
Nov 22 2015, 08:53 PM
I've been using the black sabo seals with good results for the last few years, but this one is a vr. It's been about 5 years since I built the engine.
| r_towle |
Nov 22 2015, 10:27 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Yes it is possible, I one day if you have the painted tin ready to go.
Remove the carbs now, get them soaking for a late night clean up and rebuild. Remove as many screws as you can between now and Friday night, there are quite a few you can reach from the engine bay... Order up a set of new cheese head screws, you will be happy. Stuff them into a piece of foam and paint them the same color as the new tin. Rich |
| Kansas 914 |
Nov 22 2015, 10:39 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,006 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains
Oh, and the title reminded me of: This penguin is driving his car along, and the car starts smoking so he pulls it into a garage. The mechanic agrees to look at it, so while he waits the penguin goes across the street to 7-11. He gets some ice cream and eats it while he waits but he gets it all over his face (penguins don't have hands...) He gets back to the garage and the mechanic says: "Well it looks like you just blew a seal" Penguin says: "Naw that's just a little ice cream" (IMG:style_emoticons/default/lol-2.gif) |
| euro911 |
Nov 23 2015, 12:58 AM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
| Tom_T |
Nov 23 2015, 11:12 AM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
Good luck ole buddy & have a good break for some turkey & fixins! (IMG:style_emoticons/default/chowtime.gif)
And Stu, I thought the Penguin was on the telly!? (IMG:style_emoticons/default/confused24.gif) ... good one! (IMG:style_emoticons/default/biggrin.gif) Happy Turkey Day! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
| hndyhrr |
Nov 23 2015, 11:43 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 669 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest
| JeffBowlsby |
Nov 23 2015, 11:55 AM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,209 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
If'n it were me, I would just pull the tranny and replace the seal, out the tranny back in, unless you wanted to pull the engine anyways in prep from the rebuild.
| stugray |
Nov 23 2015, 12:20 PM
And Stu, I thought the Penguin was on the telly!? (IMG:style_emoticons/default/confused24.gif) ... good one! (IMG:style_emoticons/default/biggrin.gif) No Nooo.... what's the program on the telly... |
| Eric_Shea |
Nov 23 2015, 01:16 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
| rjames |
Nov 23 2015, 02:21 PM
If'n it were me, I would just pull the tranny and replace the seal, out the tranny back in, unless you wanted to pull the engine anyways in prep from the rebuild. (IMG:style_emoticons/default/agree.gif) And then my post above applies. |
Lo-Fi Version | Time is now: 15th March 2026 - 12:00 AM |
