ChrisFix |
Member ![]() ![]() Group: Members Posts: 173 Joined: 3-March 05 From: Chapel Hill, NC Member No.: 3,707 ![]() |
I was trying to replace the windshield washer hoses that connect to the wiper switch, and this small priece fell out of the switch assembly when I was taking a washer hose off. I didn't see where it came from, so don't know where it goes. Anybody out there know the intimate details of the switch assembly. Additional switch photos to follow.
Thanks! Attached image(s) ![]() |
ChrisFix |
Wiper switch side of switch assembly...
ChrisFix |
Overall side view of assembly...
ChrisFix |
Front of assembly...
ChrisFix |
Some more trial and error and I found where it goes. Here is a pic just incase anyone else ever has the same problem. It provides ground to the column.
markb |
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California ![]() ![]() |
Thanks! I've got one sitting on my toolbox from pulling a switch apart last week. Now I can put it back in. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
ChrisFix |
I'm glad that someone else good use that info. In case it isn't clear from the photo, the connector sits just above the opening on the left side of the assembly (where the washer tubes connect). The upper left screw (one of the four skinny ones that hold the assembly in) passes through the hole of the connector to keep in in place.
Lo-Fi Version | Time is now: 11th July 2025 - 01:16 PM |
