Windshield Sealer issue?, Plus: Bonus 30 years sitting startup video |
Gcthielen |
Dec 3 2015, 10:32 AM
Newbie Group: Members Posts: 37 Joined: 14-August 13 From: Dayton OH Member No.: 16,251 Region Association: Upper MidWest |
I purchased a windshield and 3m butyl wound ribbon sealer from Sierra Madre last year and am now just getting around to installing the chrome trim. It won't quite snap into place and I fear that the sealer is too thick. SM has been very helpful, but has never run into this problem.
Has anyone else had this problem? Does anyone know what thickness is recommended. The SM bagged sealer did not list the thickness. Thanks, George Thielen Dayton OH Bonus Video of first start up in 30 years.. https://www.youtube.com/watch?v=Y71MzugT7l0 |
worn |
Dec 3 2015, 11:00 AM
can't remember Group: Members Posts: 3,163 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I purchased a windshield and 3m butyl wound ribbon sealer from Sierra Madre last year and am now just getting around to installing the chrome trim. It won't quite snap into place and I fear that the sealer is too thick. SM has been very helpful, but has never run into this problem. Has anyone else had this problem? Does anyone know what thickness is recommended. The SM bagged sealer did not list the thickness. Thanks, George Thielen Dayton OH Bonus Video of first start up in 30 years.. https://www.youtube.com/watch?v=Y71MzugT7l0 How warm is your garage? I just did the rear window at around 60 and it was harder that way. |
ChrisFoley |
Dec 3 2015, 11:10 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
You probably need a real warm place in the sun to soften the butyl tape, and press the windshield in a little further.
Gcthielen |
Dec 3 2015, 11:40 AM
ChrisFoley |
Dec 3 2015, 12:37 PM
A couple of infrared heat lamps aimed at the windshield might do the trick.
tweet |
Dec 3 2015, 01:08 PM
Member Group: Members Posts: 200 Joined: 25-February 13 From: South Florida Member No.: 15,579 Region Association: South East States |
Hairdryer or heat gun perhaps? You can control how much and where you want the heat.
ChrisFoley |
Dec 3 2015, 01:22 PM
Mueller |
Dec 3 2015, 06:55 PM
Electric blanket?
turk22 |
Dec 3 2015, 08:56 PM
Treetop Flyer Group: Members Posts: 735 Joined: 27-July 12 From: Cincinnati OH Member No.: 14,725 Region Association: Upper MidWest |
great video!
porschetub |
Dec 4 2015, 12:07 AM
Advanced Member Group: Members Posts: 4,705 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I purchased a windshield and 3m butyl wound ribbon sealer from Sierra Madre last year and am now just getting around to installing the chrome trim. It won't quite snap into place and I fear that the sealer is too thick. SM has been very helpful, but has never run into this problem. Has anyone else had this problem? Does anyone know what thickness is recommended. The SM bagged sealer did not list the thickness. Thanks, George Thielen Dayton OH Bonus Video of first start up in 30 years.. https://www.youtube.com/watch?v=Y71MzugT7l0 are the trim clips properly in place or jammed up with the sealer,and by the way the trim needs to be carefully test fitted and adjusted to snap in place,no one can remove it without bending it,maybe you already know that however. Good luck,appears Chris has been there??? |
dangrouche |
Dec 4 2015, 12:56 AM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
I had used 3/8" 3M butyl.
ChrisFoley |
Dec 4 2015, 11:15 AM
I had used 3/8" 3M butyl. I like the 3/8" better than 5/16" for windshields. When the glass is pushed in to the correct position it provides a nice wide contact strip on both the windshield and the frame. However, it does require some effort to press in to the correct position - even when in the sun on a warm day. |
Gcthielen |
Dec 4 2015, 01:51 PM
I purchased a windshield and 3m butyl wound ribbon sealer from Sierra Madre last year and am now just getting around to installing the chrome trim. It won't quite snap into place and I fear that the sealer is too thick. SM has been very helpful, but has never run into this problem. Has anyone else had this problem? Does anyone know what thickness is recommended. The SM bagged sealer did not list the thickness. Thanks, George Thielen Dayton OH Bonus Video of first start up in 30 years.. https://www.youtube.com/watch?v=Y71MzugT7l0 are the trim clips properly in place or jammed up with the sealer,and by the way the trim needs to be carefully test fitted and adjusted to snap in place,no one can remove it without bending it,maybe you already know that however. Good luck,appears Chris has been there??? No sealer in the clips...the trim was removed by the PO and appears to be pretty straight. |
Gcthielen |
Dec 4 2015, 01:53 PM
r_towle |
Dec 4 2015, 04:42 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
It's been a long time since I looked, but are the clips supposed to be flush with the top plane of the windshield or are they sticking out proud?
I am asking for this thread, maybe he can find only certain spots that are wrong, or at least have a target height to aim for if he uses heat or removes it and redoes the windshield install. |
Mikey914 |
Dec 5 2015, 12:22 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The material needs to be warm and the windshield needs to be set at the proper height off the bottom (depth). There is a write up on it here that I put the pages of the maintenance manual in, but here it is again.
Attached image(s) |
Lo-Fi Version | Time is now: 8th June 2024 - 01:16 PM |
