baldprisonguard |
Newbie ![]() Group: Members Posts: 4 Joined: 2-January 05 From: central valley california Member No.: 3,394 ![]() |
do i have to swap the cam out to go from f/i to normal aspiration (carbs) (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
If you expect any decent performance YES.
Will it run as is YES Will it out perform a stock FI ..... NO Wil it get worse gas milage that stock FI Yes |
JoeSharp |
In Irvine, Ca. May 15-18 ![]() ![]() ![]() ![]() Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States ![]() |
I know I'm gonna get stuff for this but I just put Solex 40mm singels on an 1.8 no cam change but I did replace tha dist. with a bosch 010 that I had laying around. The motor runs much better than it did when it was injected. Linda bough the car and I don't know how she drove that car to my house. The car runs better than Lindas 1.7 when it is running perfect.
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Joe Attached image(s) ![]() |
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
Joe is that a pie tin on top of the carb?
morph |
quality parts builder ![]() ![]() ![]() Group: Members Posts: 1,828 Joined: 25-November 03 From: oregon coast Member No.: 1,389 Region Association: Pacific Northwest ![]() |
ok we gotta talk about that pie tin . (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
ive been curious about kadrons or solex on 914s.i was gonna buy a set just.just to find out what they was like . james |
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
You LIKE headaches?
JoeSharp |
Been running them for about a mounth. Those M/C hats got me through the RAIN. The carbs are have been good on gas. They sound much better than the L-jet. It cost me $500.00 to set them up new with the hex bar linkage.
Less than a Bolwsby loom and any sencer. The carbs sound kool. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Joe |
JoeSharp |
James: You can drive the car at the Wild West Classic. It is my driver,and I'm sure it will be there. M/C hats and all.
jwalters |
Sooo Close....... ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Another great thing about carbs is you can fiddle with the total timing to gain a few more HP on top of the extra HP you will get from using carbs and dialing them in properly--
Cannot do that with FI--you throw the trigger points all out of whack and eff up the whole shebang-- Ok,OK--only cause I know Lupawali will see this--- (IMG:http://www.914world.com/bbs2/html/emoticons/hide.gif) Properly set up ignition and carbs will yeild astonshing results with mileage--it is no-where as bad as some seeem to think-- With my 1.7 and dual 40's I could average about 38-42 MPG as long as if I was not stomping on it all the time--then it WOULD go down to about 28-32--but I spent over two days dialing in the whole system--but once I was done-- (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) |
JoeSharp |
I have more money in the D-Jet parts and tools to moniter it than I have in the 75 altogether. ( Bowlsby loom, MPS, CHT, an LM-1 and a VOM)
morph |
kool ill take you up on that drive. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
james |
martinef1963 |
The Saga Continues... ![]() ![]() Group: Members Posts: 320 Joined: 9-November 04 From: Miami, FL, USA Member No.: 3,080 Region Association: South East States ![]() |
I'm on the look out for some 44 IDF's - I'm going to do the switch - I too have spent a pretty penny on spare parts and can't seem to get it right (FI).
(IMG:http://www.914world.com/bbs2/html/emoticons/burnout.gif) |
JoeSharp |
Oh! I've got it right. I've got the D-Jet running the Air/Fuel Ratio between 13.3 and 14.5 %. I think I can do better. It only cost $2,00.00 for the induction. It runs awsom but that is another thread. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/bs.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) the advance/retard timing with the stock distributor has 0 negative effect with the triggering of the stock FI..... if you are using a stock distributor with carbs, then you have the same limitations as one does with the stock FI.....now with an aftermarket distributor like my Mallory, I have no problems with my D-Jet with it setup more aggresive than the stock distributor... |
Lo-Fi Version | Time is now: 17th June 2024 - 12:58 PM |
