Another great thing about carbs is you can fiddle with the total timing to gain a few more HP on top of the extra HP you will get from using carbs and dialing them in properly--
Cannot do that with FI--you throw the trigger points all out of whack and eff up the whole shebang--
Ok,OK--only cause I know Lupawali will see this---
Properly set up ignition and carbs will yeild astonshing results with mileage--it is no-where as bad as some seeem to think--
With my 1.7 and dual 40's I could average about 38-42 MPG as long as if I was not stomping on it all the time--then it WOULD go down to about 28-32--but I spent over two days dialing in the whole system--but once I was done--
