carb swap |
carb swap |
baldprisonguard |
Mar 13 2005, 02:15 PM
Newbie Group: Members Posts: 4 Joined: 2-January 05 From: central valley california Member No.: 3,394 |
do i have to swap the cam out to go from f/i to normal aspiration (carbs) (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
Joe Ricard |
Mar 13 2005, 02:46 PM
If you expect any decent performance YES.
Will it run as is YES Will it out perform a stock FI ..... NO Wil it get worse gas milage that stock FI Yes |
JoeSharp |
Mar 13 2005, 02:49 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
I know I'm gonna get stuff for this but I just put Solex 40mm singels on an 1.8 no cam change but I did replace tha dist. with a bosch 010 that I had laying around. The motor runs much better than it did when it was injected. Linda bough the car and I don't know how she drove that car to my house. The car runs better than Lindas 1.7 when it is running perfect.
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Joe Attached image(s) |
Allan |
Mar 13 2005, 03:12 PM
Joe is that a pie tin on top of the carb?
morph |
Mar 13 2005, 03:19 PM
quality parts builder Group: Members Posts: 1,828 Joined: 25-November 03 From: oregon coast Member No.: 1,389 Region Association: Pacific Northwest |
ok we gotta talk about that pie tin . (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
ive been curious about kadrons or solex on 914s.i was gonna buy a set just.just to find out what they was like . james |
Joe Bob |
Mar 13 2005, 03:47 PM
You LIKE headaches?
JoeSharp |
Mar 13 2005, 04:03 PM
Been running them for about a mounth. Those M/C hats got me through the RAIN. The carbs are have been good on gas. They sound much better than the L-jet. It cost me $500.00 to set them up new with the hex bar linkage.
Less than a Bolwsby loom and any sencer. The carbs sound kool. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Joe |
JoeSharp |
Mar 13 2005, 04:11 PM
James: You can drive the car at the Wild West Classic. It is my driver,and I'm sure it will be there. M/C hats and all.
jwalters |
Mar 13 2005, 04:19 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Another great thing about carbs is you can fiddle with the total timing to gain a few more HP on top of the extra HP you will get from using carbs and dialing them in properly--
Cannot do that with FI--you throw the trigger points all out of whack and eff up the whole shebang-- Ok,OK--only cause I know Lupawali will see this--- (IMG:http://www.914world.com/bbs2/html/emoticons/hide.gif) Properly set up ignition and carbs will yeild astonshing results with mileage--it is no-where as bad as some seeem to think-- With my 1.7 and dual 40's I could average about 38-42 MPG as long as if I was not stomping on it all the time--then it WOULD go down to about 28-32--but I spent over two days dialing in the whole system--but once I was done-- (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) |
JoeSharp |
Mar 13 2005, 04:33 PM
I have more money in the D-Jet parts and tools to moniter it than I have in the 75 altogether. ( Bowlsby loom, MPS, CHT, an LM-1 and a VOM)
morph |
Mar 13 2005, 06:51 PM
kool ill take you up on that drive. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
james |
martinef1963 |
Mar 13 2005, 08:23 PM
The Saga Continues... Group: Members Posts: 320 Joined: 9-November 04 From: Miami, FL, USA Member No.: 3,080 Region Association: South East States |
I'm on the look out for some 44 IDF's - I'm going to do the switch - I too have spent a pretty penny on spare parts and can't seem to get it right (FI).
(IMG:http://www.914world.com/bbs2/html/emoticons/burnout.gif) |
JoeSharp |
Mar 13 2005, 09:58 PM
Oh! I've got it right. I've got the D-Jet running the Air/Fuel Ratio between 13.3 and 14.5 %. I think I can do better. It only cost $2,00.00 for the induction. It runs awsom but that is another thread. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Mueller |
Mar 13 2005, 11:50 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/bs.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) the advance/retard timing with the stock distributor has 0 negative effect with the triggering of the stock FI..... if you are using a stock distributor with carbs, then you have the same limitations as one does with the stock FI.....now with an aftermarket distributor like my Mallory, I have no problems with my D-Jet with it setup more aggresive than the stock distributor... |
Lo-Fi Version | Time is now: 6th May 2024 - 09:34 AM |
