Woody's Custom Shop mini amp, speaker issue? |
porschetub |
Dec 7 2015, 02:21 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Purchased one of these small amps for eventual use with my Blaupunkt Frankfurt stereo but it appears this isn't to be (IMG:style_emoticons/default/WTF.gif) .
The instructions state and I quote "it is not recommended that this unit shares speakers with the radio,this unit is more powerful than most radio's and voltage will feedback into the original radio and burn it out''........bloody marvelous not. Anyone sorted this issue or do I just run it thru the din amp connection on the rear of which I have 2 ,one is a six pin and the other a seven from memory. My understanding is that the bridging caps into the two rear din female plugs are to enable the sound from the built-in amp,when these are removed (one or the other)the headunit then receives amplification from and external source......is this correct. Can add a pic of these plugs if required,thanks in advance. |
Andyrew |
Dec 7 2015, 02:51 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Are you planning on using it as an amp or as its own music source?
porschetub |
Dec 7 2015, 03:04 PM
Are you planning on using it as an amp or as its own music source? Andrew I would like to use it as an amp to kick the Frankfurt along which is most likely only 5W per channel,but it may only be designed as a separate music source I don't really know (IMG:style_emoticons/default/confused24.gif) . |
Andyrew |
Dec 7 2015, 03:09 PM
Run it in line like a normal amp. The way I read what you wrote from the instructions is not to run it in parallel to a radio. IE speakers with two feeds. If you run this in line power should not go back to the stereo.
Jeffs9146 |
Dec 7 2015, 03:13 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
porschetub |
Dec 8 2015, 12:45 AM
Run it in line like a normal amp. The way I read what you wrote from the instructions is not to run it in parallel to a radio. IE speakers with two feeds. If you run this in line power should not go back to the stereo. Sorry to sound a dumb-ass but I presumed if I ran it with a din plug into the headunit it would be ok?. By the way thanks for the replacement light switch works a treat. |
jim_hoyland |
Dec 8 2015, 06:42 AM
Get that VIN ? Group: Members Posts: 9,318 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
porschetub |
Dec 8 2015, 11:52 AM
Thanks Jim that was my next question. |
Kansas 914 |
Dec 8 2015, 12:17 PM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
It converts "Hi Output" or Speaker Level Audio to Line Level which is typically used before an amp. If speaker level was introduced to an amp it would probably damage/overdrive it. We used to do that intentionally in the 60's for a cool guitar or organ sound. I used a Bogen PA amp in front of a Fender amp. |
Jeffs9146 |
Dec 8 2015, 12:34 PM
It converts "Hi Output" or Speaker Level Audio to Line Level which is typically used before an amp. If speaker level was introduced to an amp it would probably damage/overdrive it. We used to do that intentionally in the 60's for a cool guitar or organ sound. I used a Bogen PA amp in front of a Fender amp. (IMG:style_emoticons/default/agree.gif) You can then add a a/b line switch into the amp and run two different devices into the amp. |
Kansas 914 |
Dec 8 2015, 12:41 PM
(IMG:style_emoticons/default/agree.gif) You can then add a a/b line switch into the amp and run two different devices into the amp. Look at the price for the unit at New Egg: I think we disconnected the output transformer from the Bogen now that I think about it.... |
Jeffs9146 |
Dec 8 2015, 12:48 PM
(IMG:style_emoticons/default/agree.gif) You can then add a a/b line switch into the amp and run two different devices into the amp. Look at the price for the unit at New Egg: I think we disconnected the output transformer from the Bogen now that I think about it.... Walmart has it for $4.73 |
Andyrew |
Dec 8 2015, 05:34 PM
Pretty sure he was commenting on the 9.14 (IMG:style_emoticons/default/smile.gif)
Jeffs9146 |
Dec 8 2015, 05:40 PM
Kansas 914 |
Dec 8 2015, 05:53 PM
r_towle |
Dec 8 2015, 06:53 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Anyone use the low profile sub woofers that are supposed to fit under a seat?
Lo-Fi Version | Time is now: 7th June 2024 - 11:08 AM |
