D-Jet TPS Differences, Difference Between 1.7 and 2.0 TPS |
Highland |
Dec 10 2015, 09:06 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
I was wondering if I can replace the board in 1.7 TPS and use it in a 2.0 stock D-jet system.
Are the boards the only difference? |
JeffBowlsby |
Dec 10 2015, 09:54 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Not interchangeable, they rotate in opposite directions. Both replacement boards are available.
davesprinkle |
Dec 10 2015, 11:31 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
As Jeff said, these sensors rotate in different directions. And you cannot swap boards between sensors because the wipers are different as well.
Mikey914 |
Dec 11 2015, 11:52 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
You can bend the arms slightly to make them follow a slightly different (unworn) path. or better yet replace them.
Highland |
Dec 11 2015, 12:18 PM
NJ914 |
Dec 13 2015, 07:09 AM
Newbie Group: Members Posts: 37 Joined: 2-November 15 From: Bernardsville, NJ Member No.: 19,324 Region Association: North East States |
I have a similar issue with my TPS. Board is scratched but more of the issue is the arms are bent a bit. Can you get new arms? Where? Does anyone have a photo of a 2.0 TPS with the arms in their correct position at idle?
BeatNavy |
Dec 13 2015, 07:29 AM
I don't think I've ever seen just the arms for sale. Maybe put a WTB in classifieds for a whole TPS?
Mikey914 |
Dec 13 2015, 02:35 PM
No the arms are not available, but you can replace the board. I wouldn't try bending the "back" but the new board should solve your issue.
boxsterfan |
Dec 13 2015, 08:47 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Everything you ever wanted to know about D-Jet here:
http://members.rennlist.com/pbanders/djetparts.htm |
Lo-Fi Version | Time is now: 8th June 2024 - 01:05 PM |
