| kupcar |
Dec 16 2015, 10:28 AM
Member ![]() ![]() Group: Members Posts: 95 Joined: 14-February 13 From: Chicago Member No.: 15,528 Region Association: None |
My 914-6 conversion probably needs some sort of catch can. The previous owner has the crankcase vented to the oil tank. The vent from the tank simply has a sponge zip tied to the opening. It seems to work ok and I've never had a issue with anything but there has to be a better alternative. Something simple. Do most use a catch can, or can a small mesh filter be used? I cleaned a bit of oil residue off the motor when I was detailing the car. My guess is it came from venting into the engine compartment. Now that it looks pretty, I'd like to keep it that way. Any suggestions? Thanks.
| SirAndy |
Dec 16 2015, 12:26 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I used an old Gatorade bottle with a few holes drill on top to relieve pressure. Works great for collecting the oil vapors and moisture.
I turned the holes in the bottle to face the air filter so any vapors escaping get burnt. (IMG:style_emoticons/default/biggrin.gif) (IMG:http://www.914world.com/bbs2/uploads/post-179-1255294222.jpg) |
| stugray |
Dec 16 2015, 01:13 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
At the track I am often amazed how many can put the most redneck oil catch can on an otherwise beautiful car.
Yours above is actually nice compared to some :-) I think it's kind of like a redneck badge of honor having a Budweiser can ziptied to your vintage racecar..... |
| Andyrew |
Dec 16 2015, 01:17 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
This is the one I am going to use.
Gonna fill it with stainless steel wool. http://www.ebay.com/itm/201249093731?_trks...K%3AMEBIDX%3AIT |
| boxsterfan |
Dec 16 2015, 01:20 PM
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
What's the part# on that gatorade bottle? (IMG:style_emoticons/default/biggrin.gif)
| SirAndy |
Dec 16 2015, 01:40 PM
What's the part# on that gatorade bottle? (IMG:style_emoticons/default/biggrin.gif) Kinda hard to read in the pic but i think it starts with GAT ... (IMG:style_emoticons/default/shades.gif) |
| Jeffs9146 |
Dec 16 2015, 04:58 PM
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Attached thumbnail(s) |
| kupcar |
Dec 16 2015, 05:18 PM
A+ for creativity across the board. Has anyone ever puked up enough oil to catch anything? I'm tempted to stick a k&n crankcase breather on the vent opening.
| r_towle |
Dec 16 2015, 05:22 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
(IMG:style_emoticons/default/smile.gif) Andy is a redneck......hahahaha
Not something I would say.... |
| SirAndy |
Dec 16 2015, 05:44 PM
Has anyone ever puked up enough oil to catch anything? Absolutely! I have to clean out the catch-can every other week and it's usually pretty full after an autocross. (IMG:style_emoticons/default/driving.gif) |
| SirAndy |
Dec 16 2015, 05:45 PM
(IMG:style_emoticons/default/smile.gif) Andy is a redneck......hahahaha Not something I would say.... I've heard worse ... (IMG:style_emoticons/default/biggrin.gif) |
| patssle |
Dec 16 2015, 06:08 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Running Gatorade here too. Andy was my inspiration.
| Jeffs9146 |
Dec 16 2015, 06:15 PM
A+ for creativity across the board. Has anyone ever puked up enough oil to catch anything? I'm tempted to stick a k&n crankcase breather on the vent opening. You can see the mess around my catch bottle when it blew off before I drilled a vent hole. It can be 1/4" to 1/2" a week depending on how hard you are driving it. |
| mb911 |
Dec 16 2015, 06:26 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,729 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
I made one for my last 6 .it was a piece of 2" aluminium tubing with a bottom welded on with a fitting on top for a small k&n filter with a hose fitting on the side.. I attached it to the fan housing opposite of the coil.. It worked great..
I should make a bunch of them |
| TheCabinetmaker |
Dec 16 2015, 06:45 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I had a carbed 4 for a while that used a small air compressor water separator. Clear cylinder with a petcock on the bottom for draining. Worked great and no oily residue in engine bay.
| 11tenths |
Dec 16 2015, 08:01 PM
Ve get too soon old, und too late schmart ![]() ![]() Group: Members Posts: 142 Joined: 11-October 12 From: Islip, Long Island, NY Member No.: 15,026 Region Association: North East States
If only the factory had put one under the battery tray...
| porschetub |
Dec 16 2015, 08:31 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,065 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
A+ for creativity across the board. Has anyone ever puked up enough oil to catch anything? I'm tempted to stick a k&n crankcase breather on the vent opening. I posted a the same thread on here recently ,some said the K&N will oil mist your engine bay,I researched and found that you need to buy a can that has the largest fitting possible to work,I bought a D1 boy racer 600ml unit with 15mm fittings,appears there not many much bigger. I then acquired a silicone reducer to go from my PMS filler neck (24mm) to 15mm on catch can. I haven't decided if I go to a breather in the top of the can or run a hose back to the block,the fitting is already tapped so that's an option . I presume the case is in some point of vacuum so this should pull the separated fumes from the can ??,the tank breather works this way so all should be good. I don't have the option to run into the intake and don't want to besides. |
| porschetub |
Dec 16 2015, 10:01 PM
I had a carbed 4 for a while that used a small air compressor water separator. Clear cylinder with a petcock on the bottom for draining. Worked great and no oily residue in engine bay. yea that would work well as its designed for that,these are very effective,same principle different application....right. |
| Downunderman |
Dec 17 2015, 12:42 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 852 Joined: 31-May 03 From: Sydney, Australia Member No.: 766 Region Association: Australia and New Zealand |
I vented the catch tank on my 6 back into the bottom of the air cleaner so it avoided the filter and got sucked back into the motor.
| stugray |
Dec 17 2015, 12:44 AM
here's mine for a 4:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1450334677.1.jpg) The added white piece on the stock filler-neck/breather-box was to allow me to attach a very large dia hose and to point towards the drivers side. |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:54 PM |
