Loctite vs. Permatex, Both high temp formulas |
Allan |
Mar 14 2005, 02:27 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I'm going to plug off my air injection ports in my heads this evening and would like a general consensus on the best sealant to use. I will be using the old valve adjust screws and want to make sure that they don't back out but also that I may be able to remove them in the future if the need arises. I was thinking either Loctite high temp or Permatex high temp teflon. What'ya think?
Cap'n Krusty |
Mar 14 2005, 03:06 PM
Loctite and Permatex have been the same company for years. Despite the temptation to "take the easy way out", you need to know the flange on the ait injector is the sealing surface, NOT the threads, so you run the risk of the plug leaking if the threads are not perfect, and leaks past the threads can further burn the head and cause permanent problems. I suggest you plug a set of injectors, either by brazing the top end, using a threaded cap, or tapping the bore for a plug. More work now, trading off against a potential major problem in the future. HTH, The Cap'n
Allan |
Mar 14 2005, 04:17 PM
I was looking at the injector tubes and the flanges butts up against the cooling fin on the head and wont go any deeper. I can't figure out how it would seal without running all the way through the fins and seat up against the head. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Allan |
Mar 14 2005, 09:19 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) Or JB Weld?
Allan |
Mar 14 2005, 09:42 PM
Okay, I'll wait another day. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
McMark |
Mar 14 2005, 10:32 PM
How come one of our amazing members hasn't created a plug that will work as good as a braized pipe, but looks nicer. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Allan |
Mar 15 2005, 12:00 AM
I don't know!! I wish they would. I'm going with JB weld. I hope I never have to get in there again.
mightyohm |
Mar 15 2005, 12:13 AM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
I think that is an oxymoron. |
Allan |
Mar 15 2005, 12:26 AM
(IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) You're right! No matter what I'm screwed. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Lo-Fi Version | Time is now: 3rd June 2024 - 08:19 AM |
