Throttle linkage -6 conversion |
maddin |
Dec 17 2015, 08:09 PM
Member Group: Members Posts: 168 Joined: 22-December 13 From: Australia Member No.: 16,789 Region Association: Australia and New Zealand |
Hi there,
could somebody please point me in the right direction.Slightly confused which part to get... I have a 72' 914 conversion with a 78' 3.0l with CIS. I need the throttle linkage and the ball cup on the engine but not sure which one exactly... Would that be the one? Throttle linkage #90142302603 Is there a difference in the linkage between carbs and CIS? AA has a few different ball cups but none for a 78'..are they the same as the 77' model? Ball cups should I get new bushings too? Thanks (IMG:style_emoticons/default/smile.gif) |
914Sixer |
Dec 18 2015, 07:24 AM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
OOPS I thought you needed the floor mount.
Jeffs9146 |
Dec 18 2015, 11:56 AM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I purchased the bell crank and mount and made my own throttle bar. I have a 3.0L CIS if you need photos! I used the stock throttle linkage and mount on the motor but I think I had to move the ball on the pivot. I can't remember exactly! (IMG:style_emoticons/default/blink.gif)
Attached thumbnail(s) Attached image(s) |
porschetub |
Dec 18 2015, 12:31 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
[quote name='maddin' date='Dec 18 2015, 03:09 PM' post='2278387']
Hi there, could somebody please point me in the right direction.Slightly confused which part to get... I have a 72' 914 conversion with a 78' 3.0l with CIS. I need the throttle linkage and the ball cup on the engine but not sure which one exactly... Would that be the one? Throttle linkage #90142302603 Is there a difference in the linkage between carbs and CIS? AA has a few different ball cups but none for a 78'..are they the same as the 77' model? Ball cups should I get new bushings too? Thanks (IMG:style_emoticons/default/smile.gif) I bought ball cups from pelican the right hand thread ones are genuine and the left hand thread ones were aftermarket from memory. I found there was wear in some and not in others,best to check and order the ones to replace the worn ones as they cause lost motion in the whole system and you may not get full throttle,least that's how mine was. Steer away from AA for part supply ,besides pelican offer a great service and are closer to you freight wise. I personally wouldn't buy the linkage new,no sense in cutting up a new one which you may have to do,I payed $30 for a good one and cut that to suit length wise. Edit,yes get all the bushes @ the same time,cheers. |
Jeffs9146 |
Dec 18 2015, 12:49 PM
notice the ball on my pivot is on the other side of the arm from the one in the bottom photo! I also ground down the corner spot so the shaft didn't hit it.
Mark Henry |
Dec 18 2015, 01:20 PM
This part I just made my own out of a 911 part...but in reading the OP's 1st post it looks like he is looking for a solution that can be purchased.
(IMG:http://www.914world.com/bbs2/uploads/post-128-1450461406.jpg) |
JmuRiz |
Dec 18 2015, 02:16 PM
914 Guru Group: Members Posts: 5,434 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Rich Johnson makes a full kit, with new cables and all.
a914guy |
maddin |
Dec 21 2015, 04:17 PM
Excellent! Thanks everybody for the input!
Much appreciated :-) @Jeff I really like your car! :-) |
Lo-Fi Version | Time is now: 8th June 2024 - 02:26 PM |
