D-Jet questions..... |
Mueller |
Jan 28 2003, 02:34 PM
This is my first D-jet injected 914....all the others have had L-Jet so excuse the silly questions.........
Background: Just installed a complete '76 2.0 motor into my '74 2.0 chassis... Does this part get grounded to the chassis? (IMG:http://www.pelicanparts.com/catalog/images/fuel_injection/914_pressure_sensor.JPG) What can I not hook up vacuum line related to easy the assembly and trouble shooting of the system? |
jonwatts |
Jan 28 2003, 03:47 PM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
That MPS is preeeeeeeeety. I don't know if it grounds to the chassis (check the wiring diagrams?). The mounting bracket for it should have rubber grommets through the bolt holes but that may be more for vibration than insulation.
If you cap off the air injection ports (the air pump is already removed) then I believe everything else is standard D-Jet (which doesn't mean much to you or I, understandably). Chime in here Brad. |
JeffBowlsby |
Jan 28 2003, 03:56 PM
914 Wiring Harnesses Group: Members Posts: 8,535 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
No ground for the MPS Mike. Just the 4 pole connection off the FI harness and the vacuum line from the air plenum. The rubber mounts are for vibration isolation only.
Welcome to D-Jet! |
Mueller |
Jan 28 2003, 04:01 PM
thanks Jeff.....
"welcome to D-jet"....oh joy (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) I just hope it gives me no major troubles.....I don't want to spend a dime on this system knowing that the engine is only temporary until the Megasquirted 2.0 replaces this "borrowed" 2.0 Mike |
Bleyseng |
Jan 28 2003, 04:10 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Don't hook up the vacuum lines to the Decel valve and AAR valve, plug them. You should hook up the EGR hose to bleed off the engine pressure. Keep it simple til you have it running good, then add on the other stuff. You don't even have to use the vacuum retard hose to the distributor just hook up the adv hose if you can. Check like crazy for vacuum leaks .
Oh, and as noted the MPS just mounts with rubber isolaters. Make sure the ground block for the FI is new and shiney. Geoff (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 11th June 2024 - 10:44 PM |
