sealant |
sealant |
80cap |
Dec 27 2015, 01:38 PM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
I about to reinstall the a pillar trim and rubber. I see the factory used some kind of sealant between the a pillar trim and body work. Is this RTV or some other adhesion.
One step at a time! Brian (IMG:style_emoticons/default/idea.gif) |
80cap |
Dec 28 2015, 06:06 AM
I about to reinstall the a pillar trim and rubber. I see the factory used some kind of sealant between the a pillar trim and body work. Is this RTV or some other adhesion. One step at a time! Brian (IMG:style_emoticons/default/idea.gif) bump |
Cracker |
Dec 28 2015, 07:13 AM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
I don't know buy I felt bad no one chimed in...someone has got to know this - "pretty please" those with magnificent knowledge.
Bump. Tony |
Evill Ed |
Dec 28 2015, 08:16 AM
Member Group: Members Posts: 238 Joined: 28-February 03 Member No.: 371 Region Association: None |
I about to reinstall the a pillar trim and rubber. I see the factory used some kind of sealant between the a pillar trim and body work. Is this RTV or some other adhesion. One step at a time! Brian (IMG:style_emoticons/default/idea.gif) If you are referring to sealant between the metal backer strip and the body, it is black butyl. 3M make it, it is called strip caulk, also referred to as dum dum in the auotbody trade. Summit Racing has it http://www.summitracing.com/parts/tes-0857...CFZaPHwody5wNjw Regards, Ed |
80cap |
Dec 28 2015, 09:26 AM
I about to reinstall the a pillar trim and rubber. I see the factory used some kind of sealant between the a pillar trim and body work. Is this RTV or some other adhesion. One step at a time! Brian (IMG:style_emoticons/default/idea.gif) If you are referring to sealant between the metal backer strip and the body, it is black butyl. 3M make it, it is called strip caulk, also referred to as dum dum in the auotbody trade. Summit Racing has it http://www.summitracing.com/parts/tes-0857...CFZaPHwody5wNjw Regards, Ed Thanks Brian |
cary |
Dec 29 2015, 12:24 AM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
rgalla9146 |
Dec 29 2015, 10:12 AM
Advanced Member Group: Members Posts: 4,564 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I about to reinstall the a pillar trim and rubber. I see the factory used some kind of sealant between the a pillar trim and body work. Is this RTV or some other adhesion. One step at a time! Brian (IMG:style_emoticons/default/idea.gif) It probably was RTV or butyl originally. Those strips can be hell to remove. DumDum is probably a better choice today, it will allow easier adjustment later. But it should be flattened so that the trim will lay flat. |
pdlightning |
Dec 30 2015, 10:42 PM
Member Group: Members Posts: 207 Joined: 4-February 11 From: Santa Clarita Member No.: 12,660 Region Association: Southern California |
I about to reinstall the a pillar trim and rubber. I see the factory used some kind of sealant between the a pillar trim and body work. Is this RTV or some other adhesion. One step at a time! Brian (IMG:style_emoticons/default/idea.gif) It probably was RTV or butyl originally. Those strips can be hell to remove. DumDum is probably a better choice today, it will allow easier adjustment later. But it should be flattened so that the trim will lay flat. I just ordered some from Amazon.com . It was under 20 bucks with free shipping for Prime members. |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:46 AM |
