Package from Wilwood Engineering just arrived !!!, Got some machining to do tonight :) |
Mueller |
Mar 15 2005, 04:18 PM
12.19" diameter rotor, it'll bolt onto to a 911 front hub and the new 4-lug billet hubs as long as I don't screw anything up with the mods (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
Attached image(s) |
Mueller |
qwerty
Attached image(s) |
machina |
Mar 15 2005, 04:35 PM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
what calipers fit?
will 15" fuchs work with it? |
Jeroen |
Mar 15 2005, 04:40 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
how they fit to a 911 hub?
I only count 4 holes (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) Does Wilwood drill 'm to your specs? |
MecGen |
Mar 15 2005, 04:44 PM
8 Easy Steps Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 |
Mueller |
Mar 15 2005, 04:45 PM
these are for my 4-piston aluminum RX-7 calipers....the standard 911 and SC, Carrera calipers might work, I'll know later on....... |
Mueller |
Mar 15 2005, 04:48 PM
what part of "Got some machining to do tonight (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) " do you not understand??? (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) yes, Wilwood will make them to the specs you want and need, not sure if they charge extra or not, I'm guessing they do......... First I'll open up the center hole to ~4.70 and then add the 5 thru holes for the rotor to be bolted to the hub just like the factory 911 one-piece rotor is. |
Mueller |
Mar 15 2005, 05:32 PM
john rogers |
Mar 15 2005, 05:34 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
Whoa looks nice. On a related note, did the studs issue ever get resolved?
Mueller |
Mar 15 2005, 06:06 PM
yes and no....I'm waiting to hear back from the company to find out if the 80mm studs will work for you....depending on how thick the metal is on your wheels....in the picture here, I have the 90mm studs, subtract ~15mm for the amount of threads that screw into the flange/hub. That leaves 75mm, subtract 25mm for the 1" inch spacer you are running.....what I am worried about is that the nut for the wheel will hit the unthreaded portion of the stud..... On the front of my car, I am using the 90mm stud, but my spacer is 1.125" thick and luckly the unthreaded portion of the stud protrudes past the spacer just about 3.5mm What I can do is send you one hub with the 90mm studs installed to test fit with your spacer and wheel....I can send it out tommorow if you want. |
Jeroen |
Mar 15 2005, 06:34 PM
keep us posted on the fitment with 911 calipers
IIRC the 911 rotors are something like 285 or 290mm dia (911 up to '89 that is) what's the thickness of these rotors? (I think you answered that in an earlier thread, but I can't remember (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) ) |
Mueller |
Mar 15 2005, 06:46 PM
the stock dia rotors are like 280mm in dia. X 20mm thick
these are 309,6mm X 20,6mm thick Wilwood does have a 280mm diameter rotor that is the same basic design as this one pictured, that unit would be better for stock calipers.........no adapters would be needed for the caliper....... |
john rogers |
Mar 15 2005, 07:02 PM
That would be fine. I think you have my address still? I have a bunch of wheels in the garage now getting tires put on and such. I have a source for racing studs (various lengths), fully threaded and I'll get it and send it off if you'd like.
Mueller |
Mar 15 2005, 07:05 PM
I still have your address......I couldn't find good quality studs fully threaded....I have a set of the cheaper ones sold by Prestige Wheel which work, but I'd feel way safer with the BBS Racing studs.... Not sure if I asked, what year are your front struts?...these hubs only work with the '73-76 struts |
john rogers |
Mar 15 2005, 07:21 PM
Front struts are 73. I agree with the studs should be NOT cheap. The ones we use are through one of the racing machine shops in the LA area that Black Forest has used for many years. I think they are like close to $200 a set (with spares)? They also make those weird sort of lug bolts with the very long hex area so deep sockets fit on there nice!.
Mueller |
Mar 16 2005, 10:51 AM
Attached image(s) |
Mueller |
Mar 16 2005, 10:52 AM
If I was to do this again, I'd use the "blank" hats Wilwood sells or possibly make the hats myself....
Attached image(s) |
Mueller |
Mar 16 2005, 10:53 AM
the "mythical" billet hub (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Attached image(s) |
Aaron Cox |
Mar 16 2005, 11:34 AM
so A) these will bolt up to my 72 911 hubs? (assuming you machine them)
(IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) whats the cost for these bad boys? c) what ginormous calipers can i mount on these rotors....adapter central! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Mueller |
Mar 16 2005, 11:57 AM
rotors are about $30 a pop..the hat is pricey at $120 ea, but you should never have to buy those again, I'm going to try and find a cheaper method...
these rotors are .81 thick, thicker rotors with the same mounting pattern are available as well, so almost any caliper can be adapted to work if one so desires..... I need to find a 911 front suspension to try these on and see what wheels work and don't work......not too high on my priority list, I need to focus on my car 1st (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 11:01 AM |
