Should I be worried?, Cleaning the 2.0 |
Nemisus |
Jan 1 2016, 02:46 PM
Member Group: Members Posts: 82 Joined: 1-October 11 From: North Bay CA Member No.: 13,631 Region Association: Northern California |
Do I decided to spend my first day of the year actually working on the 914!
Not too long into my cleaning and removing thing I came across what I feel is alarming.. Excuse my ignorance, does anyone have any idea why these 3 areas would be JB welded? I am tempted to remove it to see, but wanted to ask the experts. (IMG:http://www.914world.com/bbs2/uploads_offsite/i98.photobucket.com-13631-1451681163.1.jpg) thanks in advance! Nemi |
bandjoey |
Jan 1 2016, 02:52 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Something like a freeze plug. Called an oil something or the other. Looks like a tin plug hammered in the block. If it pops out you spill all your oil in a minute and blow the motor. Most everyone epoxy so them in for added protection.
Happy New Year! |
stugray |
Jan 1 2016, 03:54 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Its fine.
However the proper way to fix that is to remove the oil galley plugs, tap the holes, and put in threaded plugs. |
Dave_Darling |
Jan 1 2016, 06:26 PM
Those holes are where the oil galleries were drilled into the block. There are several on this end of the engine, and one or two on the other end as well. It was SOP for quite a while to epoxy over them any time they were accessible, to help keep them in place.
After 20-40 years of heat cycles, some of them get loose and start weeping oil, and some pop out alltogether (usually on a cold start) and dump the whole engine's worth of oil on the ground. The current thought is that the best fix is done during an engine rebuild; remove the plugs and replace them with threaded pipe plugs. Best done during a rebuild so you can clean out any chips from tapping the threads. While some are confident they can prevent the chips from getting into the engine, it's easiest if you can clean things thoroughly after cutting the threads. --DD |
EdwardBlume |
Jan 1 2016, 06:49 PM
Engines are fun to clean and take forever!
dangrouche |
Jan 1 2016, 07:35 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
here is my writeup of the process, with the engine intact. Its been six or seven years and motor is still going strong.
http://www.914club.com/bbs2/index.php?show...ation&st=20 |
Nemisus |
Jan 3 2016, 11:51 AM
Thank you guys for the feedback. Didn't get near as much done as I had planned for the weekend. I suppose spending any time with the 914 is time well spent.
Cheers Nemi |
Lo-Fi Version | Time is now: 7th June 2024 - 11:32 AM |
