Cam tolerance - side to side on the 6, Anybody know??? |
Mike D. |
Mar 16 2005, 12:12 AM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
I'm timing the cams on a 2.0E engine and from one side to the other the difference is consistantly .005". the lift is correct but the left always seems to come higher or lower as the case may be. The difference is greater when I slip the cam back and put the pin in the next hole.
Anybody know what the acceptable slop would be here? TIA, Mike D. |
sixnotfour |
Mar 16 2005, 12:27 AM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
If youre talking about the tolerance at overlap for timing the Cams ,
Ecams 3.0-3.3mm at overlap. 3.15mm being nominal so +/- .15 mm or .0059 thousands on each side . So if your .005 thou. side to side its with in spec. assuming that is from nominal 3.15 or .124 thousands So one side is like .122thou. and ther other .127 thou ? with a diff. of .005thou between L&R that would be OK |
ArtechnikA |
Mar 16 2005, 07:00 AM
you go to the closest hole; that's the tolerance. these engines are not really ultra-sensitive to cam timing... |
Thorshammer |
Mar 16 2005, 09:46 AM
Senior Member Group: Members Posts: 749 Joined: 11-November 03 Member No.: 1,335 |
.005 is .127mm this is very small, this is acceptable. But verify the same number after you torque the cam sprocket nut. as the slop in the pin WILL allow it to move slightly. Also make sure your pins are not worn out.
Erik Madsen |
Lo-Fi Version | Time is now: 10th June 2024 - 04:14 AM |
