Mike D.
Mar 16 2005, 12:12 AM
I'm timing the cams on a 2.0E engine and from one side to the other the difference is consistantly .005". the lift is correct but the left always seems to come higher or lower as the case may be. The difference is greater when I slip the cam back and put the pin in the next hole.
Anybody know what the acceptable slop would be here?
TIA,
Mike D.
sixnotfour
Mar 16 2005, 12:27 AM
If youre talking about the tolerance at overlap for timing the Cams ,
Ecams 3.0-3.3mm at overlap.
3.15mm being nominal so +/- .15 mm or .0059 thousands on each side .
So if your .005 thou. side to side its with in spec. assuming that is from nominal 3.15
or .124 thousands
So one side is like .122thou. and ther other .127 thou ? with a diff. of .005thou between L&R
that would be OK
ArtechnikA
Mar 16 2005, 07:00 AM
QUOTE (Mike D. @ Mar 16 2005, 01:12 AM) |
...The difference is greater when I slip the cam back and put the pin in the next hole.
Anybody know what the acceptable slop would be here? |
you go to the closest hole; that's the tolerance.
these engines are not really ultra-sensitive to cam timing...
Thorshammer
Mar 16 2005, 09:46 AM
.005 is .127mm this is very small, this is acceptable. But verify the same number after you torque the cam sprocket nut. as the slop in the pin WILL allow it to move slightly. Also make sure your pins are not worn out.
Erik Madsen
