Cam tolerance - side to side on the 6, Anybody know??? |
Mike D. |
Mar 16 2005, 12:12 AM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
I'm timing the cams on a 2.0E engine and from one side to the other the difference is consistantly .005". the lift is correct but the left always seems to come higher or lower as the case may be. The difference is greater when I slip the cam back and put the pin in the next hole.
Anybody know what the acceptable slop would be here? TIA, Mike D. |
Lo-Fi Version | Time is now: 19th May 2024 - 03:26 AM |
