brake calipers |
brake calipers |
RonnieJ |
Jan 8 2016, 12:41 PM
RonnieJ Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest |
Forgive me if this has been ask a thousand times but is there any alternative rear brake calipers I can install in replacement of the stock 914 rear calipers? Looking for something that is a direct replacement.
max72914 |
Jan 18 2016, 12:59 AM
Newbie Group: Members Posts: 43 Joined: 17-February 15 From: Bellingham, WA Member No.: 18,447 Region Association: Pacific Northwest |
Forgive me if this has been ask a thousand times but is there any alternative rear brake calipers I can install in replacement of the stock 914 rear calipers? Looking for something that is a direct replacement. Hi, I was in the same situation a couple months ago, I was searching everywhere for an alternative for my front calipers on my 71. Checked Oreilly's, they've got a set that they would special order from across the country, 35 for the caliper 60 for the shipping or something like that, but I would honestly just recommend toughing it out and getting the calipers at PMB, it ran me 300, but they're definitely worth it. Hope this helps |
Dave_Darling |
Jan 18 2016, 09:58 AM
There are options.
There aren't good options. The Ferrari 308 used the same type of caliper in the rear that our 914 does. The piston size is different, though, so it will change the bias on your brake system. Guess how much those cost, with the Prancing Horse label attached? (Hint: The F-car guys used to buy the $$$$ 914-6 calipers and use them as cheap replacements...) You can put front brake calipers on the back with a little creativity. This will also change the brake balance, and will leave you with no parking brake at all. Line locks can help restore parking brake function, but they tend to let go at random and leave your car (which you parked at the top of a hill) at the bottom of the hill halfway through someone's door. Putting larger brakes in the back is a good way to have the car swap ends when you push the middle pedal hard. Exciting, but in all the wrong ways. My advice is to suck it up and go to PMB. --DD |
Eric_Shea |
Jan 18 2016, 02:40 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
There are options. There aren't good options. Sure there are... http://www.pmbperformance.com/catalog/item...676/9712726.htm (IMG:style_emoticons/default/biggrin.gif) I think you meant there aren't cheap options. QUOTE The Ferrari 308 used the same type of caliper in the rear that our 914 does. The piston size is different, though, so it will change the bias on your brake system. Guess how much those cost, with the Prancing Horse label attached? (Hint: The F-car guys used to buy the $$$$ 914-6 calipers and use them as cheap replacements...) We actually used to get the Ferrari calipers cheaper until all of the Ferrari bone-yards caught on. The Ferrari calipers have the bleeder on the wrong side. That will require custom machining to add an additional bleeder ala the late model 914 calipers. $$$$ With the change in the bias, you should have 48mm pistons up front. This will give you a factory 1.6:1 bias ratio. 911 caliper$ ba$ically. Dont want to have 911 calipers up front? You'll be rear bias heavy now and can spin in a panic stop. QUOTE You can put front brake calipers on the back with a little creativity. This will also change the brake balance, and will leave you with no parking brake at all. Line locks can help restore parking brake function, but they tend to let go at random and leave your car (which you parked at the top of a hill) at the bottom of the hill halfway through someone's door. Putting larger brakes in the back is a good way to have the car swap ends when you push the middle pedal hard. Exciting, but in all the wrong ways. Yup... (IMG:style_emoticons/default/thumb3d.gif) QUOTE My advice is to suck it up and go to PMB. --DD Awe... (IMG:style_emoticons/default/wub.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 01:31 AM |
