Pedrini Wheels, Pedrini Wheels |
Samoroso72 |
Jan 8 2016, 07:41 PM
Newbie Group: Members Posts: 23 Joined: 26-July 15 From: Rhode Island Member No.: 18,999 Region Association: North East States |
Guys,
I need some help. I am fairly new to the world of 914s. I purchased a set of Pedrini at a very low price and put them in storage while I was working on my car. I recently noticed I have two different types. No laughing please. I have an early 72 1.7. Can you tell me which rim pictured below is the correct rim for my car. |
Samoroso72 |
Jan 8 2016, 07:43 PM
914Mike |
Jan 8 2016, 07:57 PM
Member Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
Should be a part number on the back. 00 is early, 01 is late.
Late ones have a recess for the late style front hub with the centering ring. Top one is the early style, IIRC. I'm in almost the same boat, early version fit my '71, until it became 5-lug. Now the Pedrini's won't fit the front of my '74, nor my '69 Ghia because of the centering rings. |
Tom_T |
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Look at the cast date numbers on the back of each & pick the one type closest to 72 MY & your car's production month/yr on the VIN, & also verify that all 4 are 914-xxxx part nos. back there too.
If the back has an inset cast or cut into them, then they were the later xxxx-01 part no. for 73 MY 914s with the then new hub-centric hubs up front. Being an early production 72, they would've used 71 production of the wheels up to Dec 71 & maybe even into early 72. Either way you have a couple of partial or 1/2 sets, & you'll need to sell 1-2 & source 2 of the correct casting style & numbers, if you want them correct for your car &/or are a CW c orrectness type. If you're not picky & it's for a DD, then you could put a matching pair on each side, & few people would notice the difference. Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
cwpeden |
Jan 8 2016, 08:05 PM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
Samoroso72 |
Jan 8 2016, 09:56 PM
All four have the 00 part number. The major difference is where the raise trim meets the exterior of the wheel. Three have the larger trim and one has the smaller trim. What is correct for 1972?
bandjoey |
Jan 9 2016, 10:29 AM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Take them to your local machine shop. Not a wheel place. Along with a front late hub. They will cut the back to fit like it came from the factory. I had all 4 done for $80
Samoroso72 |
Jan 9 2016, 02:09 PM
Thanks for the help. I was able to locate a few matching rims to complete my set. Now I will be on to refinishing them.
Any suggestions or tips. |
RohJay |
Jan 10 2016, 12:28 AM
Member Group: Members Posts: 189 Joined: 24-April 07 From: Colombo, SRI LANKA Member No.: 7,689 |
Might be too much bling for some :-)
TheCabinetmaker |
Jan 10 2016, 02:40 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Hey,Roh. I like those. I'm a pedrinni fan anyway, but those rock.
veekry9 |
Jan 11 2016, 01:55 AM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
Polished, Mediablasted and painted half flat,low contrast lightmetal. I found that the use of VHT aluminum with a clearcoat makes for a realistic metallic. |
RohJay |
Jan 11 2016, 01:30 PM
74ravenna |
Jan 11 2016, 03:55 PM
Member Group: Members Posts: 471 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States |
How do these stack up weight wise amongst their contemporaries?
How about the difference in weight between those and stock steelies? Looking at the photos of what people have done has made me question if I want to sell mine or not. Steve |
r_towle |
Jan 11 2016, 05:48 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Do you have matching shoes?
Lo-Fi Version | Time is now: 2nd June 2024 - 05:31 PM |
